Brake Rotors Help!!! - Defender Source
Old May 15th, 2011, 12:30 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
I am getting ready to buy new Rotors. I have a squeal that I can not seem to get rid of. I have had two different sets of rear rotors on this thing one set was from Napa was fine for awhile . Then did some serious offroading and got a squeal couldn't get rid of. I had bought a Parts Disco that the previous owmer had just put drilled and slotted rotors on. I took those off installed on Defender with new EBC pads worked great. then again I go offroading, and again squealing. Both times just squealing right when I am almost completely stopped. AAAAHHHH drives me nuts. Called AB and they recommended pulling everything apart and taking sandpaper and sand both rotors and pads to clean them up. Worked for about a day or two. Now I am thinking about buy another set of rotors. Any suggestions on what to do or what to buy
Old May 15th, 2011, 01:15 PM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Problem is not in the rotors, it's in the pads.
Old May 15th, 2011, 01:27 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
May have crystallized the pads.
Old May 15th, 2011, 03:27 PM
dchapman
Daniel Chapman
1999 D1
Find a large, empty, parking lot, or a street that does not get used much.
Run the truck in reverse at about 10mph
Brake/throttle modulate as you're going backwards. Meaning, floor it and pump the brakes hard enough to slow you down to ~10mph.
Do this for about 100 yards or so.
This will de-glaze the pads. Might have to do this several times.
The thing about EBC pads is they have ceramic in them. Ceramic does not have much stopping power until it gets hot. These types of pads are great for sports cars, but for big slow SUV's, not so much.
Lockheed pads are complete shit.
Every truck I've owned I've used Ferodo pads. Knock on wood, I've had great luck with them and rarely do they squeak.
Old May 15th, 2011, 03:38 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
Trevor said he uses nothing but Ferodo pads also. So you think the rotors are ok?
Old May 15th, 2011, 06:23 PM
agreed its the pads -
alternitive method is to re-bed them in
60mph - to 10 mph hard stop (threshold breaking, do not lock them up), repeat with a cool down cycle (10 minutes driving) about 4-6 times and it should go away.
95' D90 - daily driver..
Old May 15th, 2011, 06:53 PM
dsh12
Daniel Hayes
1994 Defender 90 Soft Top
Does that goo they put on the back of brake pads (between the pad and piston) work?
Dan
94D90 NAS 3.9 LT77 LT230T Soft Top
There are no guarantees expressed or implied of the accuracy or correctness of the contents of this message, and the Author is not liable for the taking of any action in reliance upon the contents of this message. As always, do your own research. To the extent that opinions are expressed in this message, they are not necessarily the opinions of the Author.
Old May 16th, 2011, 08:40 AM
dchapman
Daniel Chapman
1999 D1
yes.
Old May 16th, 2011, 10:44 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
You don't happen to have a part number do you? Search the forums on Ferodo and didn't find anything. See a bunch of items on google but some of those "do it all" online stores worry me a bit. TIA.
Old May 16th, 2011, 10:49 AM
dchapman
Daniel Chapman
1999 D1
No, I just call Tillery and he sends me what I need.
Old May 16th, 2011, 10:54 AM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
Part numbers STC2952FX (front) STC9188FX (rear) at Atlantic British
Old May 16th, 2011, 10:56 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Damn, you guys are fast! I don't need them this moment but will give Will a call or hit up AB when I get around to redoing the rear axle with new pads. Thanks!
Old May 16th, 2011, 11:29 AM
Yup, those are what I got with mine:
http://www.roverparts.com/Parts/9995F.cfm
Old May 16th, 2011, 02:35 PM
Ferodos are good as they are OEM and soft. Also helps to put a dab (small dab) of anti-seize on the edges of each pad (the metal where it is near the caliper).
If it happens after offroading, some cleaning of the pads/calipers should help too.
brake
Installing Slotted Brake Rotors crown14 Defender Technical Discussions 2 May 25th, 2009 06:47 PM
D90 brake rotors and pads defender1844 Smaller Projects 1 January 19th, 2008 01:40 PM
Emergency Brake Issues Ragland Defender Technical Discussions 10 April 7th, 2005 07:09 PM
