brake reservoir - Defender Source
Old November 10th, 2005, 04:18 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
brake reservoir
the brake reservoir,how is it fitted to the master cylinder,does it just push on
3rd low and BOOT IT
Old November 10th, 2005, 05:23 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Yes it pushes into those rubber fittings.
Old November 10th, 2005, 05:31 PM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
can you just get the rubber fittings as i think thats where mine is leaking
3rd low and BOOT IT
Old November 10th, 2005, 05:54 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
The parts manual doesn't show them so they must be part of either the:
STC 492 Kit Fluid Reservoir
or
STC 491 Kit Master Cylinder
I can't tell which it would be part of.
Old November 10th, 2005, 06:08 PM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
thank you
3rd low and BOOT IT
brake
Clogged brake lines? Heath Defender Technical Discussions 11 February 24th, 2006 08:39 AM
Rear brake caliper leak cgalpin Defender Technical Discussions 11 July 8th, 2005 11:56 AM
Emergency Brake Issues Ragland Defender Technical Discussions 10 April 7th, 2005 07:09 PM
