Brake Pull Issue - Defender Source
Old April 4th, 2012, 11:20 PM
discojosh2000's Avatar
discojosh2000
Josh
1995 Black ST
Brake Pull Issue
97' NAS D90-
When applying the brakes moderately hard the D90 pulls hard to the left. Here is what I have done so far. I have installed a new brake master cylinder, proportioning valve, both brand new front calipers and steel braided lines and brake pads. When I installed a new set of brake pads it seemed to slightly help but still pulls hard left. I have also used a brake hose clamp to eliminate the rear brakes to make sure the problem was coming from the front. This did not change anything. Any suggestions?
95 D90 Black ST
06 LR3 Black
10 Range Rover
Old April 5th, 2012, 12:01 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Originally Posted by discojosh2000 View Post
97' NAS D90-
Check the condition of right rotor
Old April 6th, 2012, 07:54 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Does it do it when you have it in Diff lock?
Land Rover 110
Old April 6th, 2012, 08:25 AM
Since you have eliminated the calipers as a potential source of the problem I wonder about the brake lines. Get some fresh fluid, and see if you can flush the rt side. Wondering if there is dirt in the lines.
Old April 8th, 2012, 09:22 AM
Turbofan's Avatar
Turbofan
Ethan
'73 SIII/ D90 Hybrid
Did it pull before you started replacing stuff? Where did you get the calipers from? AB? There's a chance you've got a bum caliper. As suggested, check the rears, then check the fronts. Make sure the calipers retract easily.
brake
brake light issue bschmeiser Defender Technical Discussions 3 October 10th, 2011 06:44 AM
Discovery I Brake Issue Mark McDonough Defender Technical Discussions 8 August 1st, 2011 10:27 AM
Weird brake light issue on my 97 Please HELP! Cyborg Defender Technical Discussions 8 July 12th, 2009 01:04 PM
3rd Brake Light Issue fleabus Defender Technical Discussions 2 February 7th, 2007 07:49 PM
