brake proportioning valve - Defender Source
Old July 31st, 2010, 01:28 AM
ttegt's Avatar
ttegt
Thomas Tegtmeier
1995 Defender 90
Hello....
Would anyone know if the '95 Discovery brake proportioning valve is the same as one for the '95 d-90? They look the same in pictures,,,,, Where can I find a brake proportioning valve for a '95 d-90, nobody seems to carry them? Mine seems to be leaking. Thanks
Old July 31st, 2010, 02:30 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Why not just replace it with an aftermarket adjustable one? They're readily available from places like Summit. I know my 110 doesn't have one (or a G-valve if that's what you're referring to), though I'll probably add an adjustable one when I get the rear swapped over the discs.
brake
Brake proportioning valve TDI Guy Wanted 3 April 14th, 2006 07:28 PM
Clogged brake lines? Heath Defender Technical Discussions 11 February 24th, 2006 08:39 AM
Emergency Brake Issues Ragland Defender Technical Discussions 10 April 7th, 2005 07:09 PM
