Brake problems - Defender Source
Old August 3rd, 2014, 02:58 PM
meatblanket's Avatar
meatblanket
Mike Simpson
1955 86 1986 ExMOD 110
Brake problems
This is on my 1986 Exmod 110, power brakes, disk brakes in front with non-vented rotors, drums in rear.
Here is what's wrong:
1) Excessive pedal travel
2) Brake warning light comes on if I hit the brakes hard
3) Brake will "pump up" to normal level in about 3 strokes
4) Back brakes only lock up in panic braking, front brakes ineffective
5) Sharp jab on the pedal gives resistance up high briefly, then vanishes and seems like only the rear brakes are working.
Here's what I've done so far, in the order I did it:
1) Adjusted rear brakes, bled brakes
2) Replaced master cylinder, bled brakes
3) Replaced front pads, bled brakes
4) Bled brakes
None of this has made any difference. What else can I do? I was sure that the master cylinder was the culprit, since it feels like I'm just not getting sufficient line pressure to the front. But it wasn't. Could the pdwa valve cause this problem? Calipers? It doesn't pull to one side.
The pdwa valve in this truck per the military supplemental parts catalog is NRC6515.
I've found this thing plumbed into the line going to the rear brakes. It's bolted to the inside of the right frame member. Anyone know what this is? The rear brakes are working fine so I doubt this is contributing to my issue, but I don't see it showing up in the parts manual.
Old August 4th, 2014, 08:10 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Might be a bad brake booster. have you checked the check vales operation on the booster? Checked the booster hose?
Old August 4th, 2014, 09:22 PM
BostonAndy's Avatar
BostonAndy
Andrew
Moose :: 1985 110
I'm having similar problems after driving through flooded roads last week. No warning lamp (if I have one) and no reproducible brake lock ups (probably a different issue). My gut feeling is the boost or vac pump.
Old August 4th, 2014, 09:35 PM
When you changed the pads, did you check that all 4 pistons were free? They tend to seize up over time.
Check that the hub bearings are not loose. That is a normal reason for needing to pump them up.
Did you use an OE branded master cylinder and pads?
As above, have you checked the booster?
Old August 4th, 2014, 10:45 PM
jafir's Avatar
jafir
Jafir Elkurd
Looks like you've got NRC8215 instead. Googling it suggests it was on some disc/drum setups, but microcat says it's for vented front disc/solid rear disc.
Old August 4th, 2014, 11:01 PM
Looks like cut off brake lines above what you have. Any other make do fixes in the brake system?
brake, problems
Brake problems. Help! Premoto1 Defender Technical Discussions 9 January 8th, 2014 03:45 PM
rear brake drum problems Whidbey Defender Technical Discussions 3 January 6th, 2014 11:54 AM
Brake light Electrical Problems solved Campbell Defender Technical Discussions 1 February 26th, 2010 10:41 AM
Brake wiring problems tebby Defender Technical Discussions 2 April 3rd, 2009 06:17 PM
D90 brake problems off road taoseno Defender Technical Discussions 6 July 4th, 2007 01:27 AM
