Brake problem - Defender Source
Old April 5th, 2014, 04:34 PM
akrockhound's Avatar
akrockhound
Jack
1988 RHD 110
Brake problem
Looking for anyone with a hunch what these symptoms might mean (110, RHD, V-8, 1988).
I did a search of previous threads but did not hit paydirt
  • Occasionally my brakes feel like they are old style brakes - not power brakes
  • the pedal is still firm (maybe a bit firmer actually) but I have to apply a lot more pressure to stop
  • It seems when this happens the pedal does not go as far down - its firmer and engages higher
  • vacuum hose from intake manifold is tight and in good condition
  • no obvious pulling to one side or the other when I am experiencing the problem
  • Seems totally random, I can't associate it with anything else (temperature, speed ?)
  • Is it the master cylinder, booster, that partitioning valve on the bulkhead below the master cylinder?
It is not (yet) posing an unsafe condition but if anyone recognizes the symptoms i'll be better prepared to make the necessary fixes - thanks
'88 ROW 110 5-door SOLD
'01 Disco II
'95 RRC LWB
Old April 5th, 2014, 06:17 PM
I believe firmer indicates lack of vacuum. With the ignition off, press on the brake pedal. Does it feel like that when this occurs? If yes, then you are losing vacuum somehow.
Originally Posted by pendy
I'm here for the D's
Old April 5th, 2014, 07:02 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
There is a vacuum check valve on the intake that the booster gets it's vacuum through. Check for dirt/blockage/sticking.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old April 5th, 2014, 08:42 PM
akrockhound
Jack
1988 RHD 110
check valve
No check valve at the intake manifold but the vacuum hose connects to a white plastic fitting at the servo and the parts diagram calls that a valve. I presume that 's what you are referring to. Does it pull right out of the server with a tug? It has a black rubber grommet that holds it in place. Just don't want to force it out if it has something holding it from the other side.
'01 Disco II
'95 RRC LWB
Old April 6th, 2014, 04:47 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
check for cracks on the booster around the area where the brake cylinder is mounted, It may help to get someone to depress the brake pedal while you look for movement.
regards
Gren
Old October 13th, 2014, 11:32 AM
akrockhound
Jack
1988 RHD 110
it was the valve
It turned out the problem was the valve at the intake manifold end of the brake servo vacuum line. It screws into the top of the intake manifold
The valve is spring-loaded - I think it is a one-way valve- but in mine the spring was bent and the valve was inop. Found it at Rimmer Brothers for about $5.
'01 Disco II
'95 RRC LWB
brake
Brake problem Allybezz Defender Technical Discussions 2 February 20th, 2013 05:03 PM
Parking brake problem, handle popping back UP. Hans Defender Technical Discussions 14 January 19th, 2010 02:34 PM
brake caliper bolt problem WhiteD90 Defender Technical Discussions 24 April 29th, 2008 11:10 AM
Brake light on after brake install wicks Defender Technical Discussions 6 October 13th, 2003 07:01 PM
