Brake problem - Defender Source
Old February 20th, 2013, 04:16 PM
Allybezz's Avatar
Allybezz
Alastair Bezzina
1997 Defender 90 (tdi 300)
Brake problem
Hi there! Just got my defender 90 (1997 tdi 300 model) today. It's a second hand vehicle. I took it for drive immediately after and everything ran smoothly (I took to the mechanic's workshop 4 prior to purchase to get a full review and everything seemed fine).
The problem arose tonight when I was showing my defender to my father-in-law. The brakes became very loose and I couldn't brake properly. Something tells me that there's a problem with the hydraulics or piping. Brake discs are practically new and there are no evident leaks. Master cylinders and all look fine.
Any ideas?
Cheers!
Old February 20th, 2013, 04:47 PM
Congrats and welcome to the site! If the brakes are new, maybe they were not properly bleed.
Old February 20th, 2013, 05:03 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
What he said.... Check the fluid level, then just to make sure bleed the brakes again. If you have a leak is should rear its ugly side. Also check the vacuum hose, to the brake booster, to make sure that isn't cracked. If you still have a problem your Master Cylinder may need to be replaced. If after replacing that and you still have a problem your brake booster might be bad.
Land Rover 110
brake
Parking brake problem, handle popping back UP. Hans Defender Technical Discussions 14 January 19th, 2010 02:34 PM
Emergency Brake Issues Ragland Defender Technical Discussions 10 April 7th, 2005 07:09 PM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
