Brake pipe replacement - Defender Source
Old July 3rd, 2016, 03:55 PM
fishy69
Matt Fisher
1987 110
I have to replace the front brake pipes in my 1987 RHD 110. How far down do I have to tear the front to do it? The passsenger pipe passes behind the radiator. Thanks for any advice
Old July 3rd, 2016, 04:23 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Behind the radiator?
Where is the passenger side front wheel??
Rent my
Old July 3rd, 2016, 05:19 PM
fishy69
Matt Fisher
1987 110
Sorry, it's right hand drive. It appears not all years are the same. Pipe for left front wheel goes from proportioning valve forward and across the front of the engine compartment. Some seem to go across the bulkhead.
Old July 3rd, 2016, 06:15 PM
Naplm00
Matthew
I ran mine down vertical from the valve, up the chassis towarda the front of the truck, under the motor mount and right across the front Crossmember/bumper support, then behind the fender well to the soft line connection.
Took about 45 min to make
Old July 4th, 2016, 08:43 AM
fishy69
Matt Fisher
1987 110
Thanks, did you have to take anything out of the engine compartment to do it? I'm due for a teardown, but not yet. I just want to be able to stop.
Old July 4th, 2016, 12:14 PM
Naplm00
Matthew
Nope, I ran the line with everything in place. My Ps lines run almost the same way but in reverse direction. FYI I don't have a fan shroud, so you may have to take that out of the way.
I also used bulk line and flared it in place with a Harbor freight flare kit.
Old July 4th, 2016, 12:36 PM
fishy69
Matt Fisher
1987 110
Cool. Thanks! Happy 4th!
ac, brake
Brake/Friction Pad (and maybe Brake Disc/Rotor) Replacement rijosho Defender Technical Discussions 62 March 16th, 2011 03:55 PM
Coming Soon, SS Y-pipe + Off Road Pipe Trailhead 4x4 The Vendors Loft 39 September 30th, 2009 09:02 PM
Is a NAS 110 Y-pipe the same as a 1995 D90 NAS Y-pipe evilfij Defender Technical Discussions 5 February 12th, 2009 06:10 PM
Ballpark cost for Cat Replacement in Y-Pipe hutch Defender Technical Discussions 1 January 16th, 2007 06:57 AM
Tail pipe replacement d90Monkey Defender Technical Discussions 9 March 24th, 2005 12:10 PM
