Brake pipe part number help for early LHD 90 - Defender Source
Old April 28th, 2011, 10:41 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Having a heck of a time trying to find valid part numbers for the LHD brake lines for my 1984 90. When I search on what I believe to be the proper part number I am only finding 1 or 2 places in the UK that have the parts listed and each part would have to come from a different placeif they really have them in stock
Not sure if maybe the part number have been changed to a new part number? I believe the correct parts number are.
rear brake pipe NTC1636
front master to tee LHD NRC9435
2nd front master line LHD NRC9431
right side brake pipe LHD NRC9437
Or do you think I would be better off just ditching the old style setup since I was considering replacing the mater and all of the lines anyway?
ID:	38170   Click image for larger version
Old April 29th, 2011, 07:01 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Other than the obvious lack of demand for LHD parts, the lack of parts in stock is likely because it's very common here in the UK to either make your own brake pipes or have them made by a garage. Copper-nickel brake pipe is cheap, durable and easy to form. I made new lines from the master to the back of the truck, to both rear brakes, and the small pipes that go from the flex line to the front calipers. Total investment was the equivalent of about US$75 including a flaring tool.
Tony
1984 110 "Smokey" (sold)
Old April 29th, 2011, 10:00 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
x2 on making your own.
All you need is a cutter, tubing, (ends if you can't reuse yours) and a ISO bubble flare kit and bender.
I like the bender pictured as it allows making really tight bends where needed that most benders can't do.
Any fittings, and tubing too, can be bought from Fed-hill, if you can't find it locally.
http://www.fedhillusa.com/
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old April 29th, 2011, 11:52 AM
DNinety's Avatar
DNinety
JP
1984 Ninety 200TDI
Safari posted recently in the "Vendors Loft" thread that they have a stainless kit available for LHD 110's. I don't know if they have the same for 90's, but you may want to check with him.
Initiative comes to thems that wait.
Old April 29th, 2011, 12:19 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
3/16 line, cutter and a bubble flare kit and you're done...less than $25. Buy a bulk roll of the line since once you figure out how easy it is you will most likely redo more than just the problem lines.
Old April 30th, 2011, 08:19 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
As cheap as make-your-own-lines are (i've got the kit in my garage), I do like the look of factory bent steel pipes. they just look... well, "factory" and neat.
I can never seem to get the copper stuff straightened into a perfect straighness... there's always kinks and bends that look too homemade for my taste.
Old April 30th, 2011, 05:00 PM
I would upgrade to NAS style everything and use stainless personally.
90, brake, d 90, lhd, part
1985 LHD Defender 90 in Santorini Black, SVX wheels and grill rivermike For Sale - Vehicles 2 March 20th, 2011 02:36 AM
Boost Wheels Part Number Rugbier Defender Technical Discussions 6 April 5th, 2010 05:38 PM
Part number for 300tdi D90 steering wheel? dmarchand Misc. Chit-Chat 12 June 22nd, 2004 10:28 AM
Part number for genuine roof rack? wicks Defender Technical Discussions 13 March 3rd, 2004 06:34 PM
Part Number Cross Reference Database mlepisto Misc. Chit-Chat 8 December 19th, 2003 12:52 AM
