Brake pipe blowout - Defender Source
Old January 2nd, 2008, 09:40 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Brake pipe blowout
FYI, just a caution that folks should inspect their brake piping as well as those pesky oil cooler lines. I was on MaBell in the snowstorm on New Years Day when I had a hard line let go between the master and the junction block (an inch above the junction). I was leaning on the brakes while winching my buddy's Rubicon when I felt the peddle sink. The truck was redone by ECR in 1996 when it was convererted to a coiler, so these were not 35 year old lines. New England rust strikes again. You can see why ECR uses SS these days.
Old January 2nd, 2008, 11:56 AM
Originally Posted by KevinNY
I was leaning on the brakes while winching my buddy's Rubicon ...
Old January 3rd, 2008, 06:54 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
fight the rust
ID:	11521   Click image for larger version
Matt Browne
Old January 3rd, 2008, 08:24 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
I don't see enough galvy in there Matt. Can't you dip the master cylinder too?
Old January 3rd, 2008, 08:34 AM
Maine 110's Avatar
Maine 110
Ware/Jesse
Recovering 110 Owner
can plastic be galvanized
Jesse Ware
Recovering NAS 110 Owner.
There is a thin line beyond which you really can't fake...
Old January 3rd, 2008, 10:47 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Pretty.
Can you post the bleed order on the RRC front calipers again Matt?
Never mind, found it in RAVE. Still like that bulkhead, nice galvy work that shop does.
Old January 3rd, 2008, 02:20 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Maybe. I thought only carbon fiber could. Aren't you making a series out of fiber?
Old January 3rd, 2008, 02:53 PM
Maine 110's Avatar
Maine 110
Ware/Jesse
Yep thats it fiber and TITenium Gonna use a Warp drive out of a Benz to power it too;^)
Jesse Ware
Old January 3rd, 2008, 08:30 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
I can indeed dip the master cylinder and do so at as often as possible.
Matt Browne
Old January 4th, 2008, 09:05 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
www.fedhillusa.com
Made me a new line and I had it in the mail the next day. Great stuff, hand bendable, rustproof, etc. The line I had to replace snaked it's was from the master back to the bulkhead, across to the other side and down to the junction block. With this stuff I had it installed in 10 minutes with no disassembly of components in the way, and absolute pleasure to work with.
Old January 4th, 2008, 10:44 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Nice one.
Old January 5th, 2008, 06:37 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
I would suppose the "cunifer" product to be similar to the Automec product that is widely used in other parts of the planet.....and available at Rovers Down South.
Much preferable to SS . I use all the stainless on Defenders as it is widely requested by customers due in part I'm sure to it being shiney.
Matt Browne
Old January 6th, 2008, 03:03 PM
Michael
Michael
Discovery 1998
I had great experience with fedhillusa. cunifer great. I rented their machine for free for a week and made all my lines on Truck and motorcycle - only installed a the longs ones to the rear so far. made4u T-clamps used to secure them.
brake
Rear brake caliper leak cgalpin Defender Technical Discussions 11 July 8th, 2005 11:56 AM
Emergency Brake Issues Ragland Defender Technical Discussions 10 April 7th, 2005 07:09 PM
