Brake Pedal To The Floor - Defender Source
Old January 26th, 2009, 10:50 AM
mpsteil
Michael Steil
NAS 110#23,97 ST#665
Just pulled my 110 out after a couple months of it sitting in the garage and the brake pedal goes to the floor and wont stiffen up no matter how much you pump it. The truck will barely stop itself on flat ground at a crawl.
Fluid level is good and I cant see any obvious problems. Thanks, Mike
Old January 26th, 2009, 11:00 AM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
Air in there somewhere, I would bleed the brakes first then go from that point.
Old January 26th, 2009, 01:20 PM
Treuwer's Avatar
Treuwer
Trae Reuwer
94 D90
I had a wheel bearing go bad, similar symptoms. Although I can't see how extended storage could cause a bearing to fail.
Old January 26th, 2009, 02:36 PM
mpsteil
Michael Steil
Just talked to my mechanic buddy and he says if the fluid level is good it has to be the master. Sound right to anyone here? Thanks, Mike
Old January 27th, 2009, 12:10 PM
61rover's Avatar
61rover
John Crouse
Brakes
Check the slave cylinder too. I find they fail more often than the master. Cheaper to fix too.
The bad news is that even if replacing the slave fixes the problem, the master typically goes bad soon after. Some sort of wierd symbiotic relationship. I would recommend replacing the master, slave and flex hose between them all at once if you can.
Old January 27th, 2009, 12:13 PM
61rover he said brake not clutch.
Air got into the system somehow. Bleed it out and it will fix it for the time being, but you need to figure out how it happened. Bad MC, leak in a line, bad caliper, bad wheel cylinder.
Old January 27th, 2009, 12:28 PM
wicks's Avatar
wicks
Wicks
97 Defender LE SW #44
Assuming you turned the motor on to reload the assist?
Old January 27th, 2009, 04:08 PM
mpsteil
Michael Steil
Yes, had to back the truck out of the garage and barely had enough brake to stop it at idle speed. Am going to check all items mentioned in posts and will report back with what I find. Thanks for the help. Mike
Old January 27th, 2009, 05:02 PM
61rover's Avatar
61rover
John Crouse
Brakes
Doh. Brain fart.
Old January 27th, 2009, 05:29 PM
We will just save if for the next clutch pedal goes to the floor post.
Old January 27th, 2009, 07:42 PM
mpsteil
Michael Steil
Aren't those supposed to go to the floor?
Old January 27th, 2009, 10:47 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Not without a serious fight, at least on the LT77
brake
Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest Buckon37s Defender Technical Discussions 223 September 1st, 2014 01:49 AM
Bling - Billet aluminium pedal covers Defender50th Misc. Chit-Chat 2 April 26th, 2005 03:30 PM
brake pedal mattdh Defender Technical Discussions 1 February 12th, 2005 05:35 PM
Brake pedal is hard!!?? Vadim Defender Technical Discussions 9 January 25th, 2005 01:09 PM
need wobbly brake pedal advice. januconn92 Defender Technical Discussions 6 May 24th, 2004 04:13 PM
