Brake pedal orifice hair dryer - Defender Source
Old August 1st, 2010, 11:45 AM
ORover's Avatar
ORover
Fred
NAS 110s #24 and #466
I've searched this forum without success on this issue. When I'm driving at speed, there's a blast of air from my brake pedal orifice that is insanely hot! I added a heat shield onto my catalytic converter and used Dynamat on the floor and battery box. Everything has been sealed up but all of the pressure seems to be focused about 90% on the brake pedal orifice and 10% from the clutch orifice. How do I seal these up? Thanks!!
Old July 27th, 2013, 09:13 PM
ssi19's Avatar
ssi19
scott
1995/D90
I have the same issue. Did you ever find a solution?
Old July 27th, 2013, 10:02 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
Did you close up the two inch and a half round holes on each side of the pedal box in the engine bay?
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old August 10th, 2013, 04:34 PM
ssi19's Avatar
ssi19
scott
1995/D90
How do find the 4 holes. Am I leaning into the engine bay? I can't seem to locate them.
Old September 2nd, 2013, 07:46 PM
ssi19's Avatar
ssi19
scott
1995/D90
Anyone else know how to locate these holes? Should I be laying down under the truck?
Old September 2nd, 2013, 07:50 PM
kellykortman
kelly kortman
1994 land rover defender
I have the same issue, I'm actually thinking about carving out a hole in my dash a/c unit and putting a hose / cooling blower into the same space, serious case of hot foot in the summer time. depressing to hear that the heat shield and all that other stuff didn't work. yes, let me know if you find the solution to this. it's nice in the wintertime though, not so much now.
Old September 3rd, 2013, 11:53 AM
ssi19's Avatar
ssi19
scott
1995/D90
This can't be by design. We must be missing some sort of plug or gasket. The volume of heat coming through is substantial.
Old September 3rd, 2013, 01:56 PM
Reese_D90's Avatar
Reese_D90
Reese
You need the 2 plugs. I got mine from RDS
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
Old September 3rd, 2013, 01:57 PM
kellykortman
kelly kortman
do you have a link to those plugs? or a description of how you put those in? thanks so much.
------ Follow up post added September 3rd, 2013 10:58 AM ------
or a part number and I assume that you mean Rovers down south?
Old September 3rd, 2013, 02:10 PM
ssi19's Avatar
ssi19
scott
1995/D90
Also Reese, how do we see the holes? Accessed inside engine bay? Or from under car? Save our summer!!
Old September 3rd, 2013, 02:21 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
You can also just slap a couple pieces of dynamat/b-quiet over the sides of the pedal box. It's generally helpful for when you want to get a good seal over a hole. Just clean off the grease first and it sticks like mad.
Old September 3rd, 2013, 02:43 PM
ssi19's Avatar
ssi19
scott
1995/D90
I see. Thanks for the pics! Can i access (and plug/cover) these holes from inside the footwell by shoving my hand into the brake orifice?
Old September 3rd, 2013, 02:57 PM
The design of the plug dictates that it be inserted from the outside.
It cannot be inserted from the inside (unless you are capable of some serious magic.)
Old September 3rd, 2013, 03:00 PM
ssi19's Avatar
ssi19
scott
1995/D90
Ok thx. From under the truck? Or do I need to reach down inside engine bay?
Old September 3rd, 2013, 03:01 PM
Gorilla tape. Two short squares should do.
Old September 3rd, 2013, 03:08 PM
ssi19's Avatar
ssi19
scott
1995/D90
This method can be done from inside the footwell by reaching into break orifice?
Old September 3rd, 2013, 03:18 PM
I think only a trained spider monkey will have hands small enough to reach up inside the brake pedal box from inside the cab. You'll have to attack this from the engine compartment.
Old September 3rd, 2013, 04:03 PM
Reese_D90's Avatar
Reese_D90
Reese
Open the hood and at the drivers side up by the bulkhead you will see the peddle box and the hole is about 1.5 inch in diameter. One on each side of the box. You can get the plugs or just cover with tape or dynamat.
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
Old September 3rd, 2013, 04:20 PM
ssi19's Avatar
ssi19
scott
1995/D90
Ok got it. Have tutored you all enough. Thanks everyone for the descriptions. Now I gotta get in Craigslist for a used spider monkey.
Old September 4th, 2013, 02:36 PM
ssi19's Avatar
ssi19
scott
1995/D90
*tortured* that is...
brake
Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest Buckon37s Defender Technical Discussions 223 September 1st, 2014 01:49 AM
Bling - Billet aluminium pedal covers Defender50th Misc. Chit-Chat 2 April 26th, 2005 03:30 PM
brake pedal mattdh Defender Technical Discussions 1 February 12th, 2005 05:35 PM
Brake pedal is hard!!?? Vadim Defender Technical Discussions 9 January 25th, 2005 01:09 PM
need wobbly brake pedal advice. januconn92 Defender Technical Discussions 6 May 24th, 2004 04:13 PM
