Brake pedal is hard!!?? - Defender Source
Old January 24th, 2005, 03:40 AM
Vadim
vadim
95 D90
Hi.Somehow my brake pedal act very strange lately .It is become very hard to push and it almost no brakes at all I thinking about problem with vacum ,but may be something else Any advise why is doing so?
Thank you in advance.
Vadim
Old January 24th, 2005, 10:21 AM
Blocked line or a bad MC?
Old January 24th, 2005, 11:05 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I'm more thinking that the booster went, or the vacuum line to it is no good.
Normally if the master goes, the pedal gets all squishy.
-Hans
My oil line fix
My 100k stopped odometer fix
Old January 24th, 2005, 12:33 PM
Vadim
vadim
95 D90
How I check booster?
Old January 24th, 2005, 11:08 PM
RoverChic's Avatar
RoverChic
D-90 Source P.I.
02 D2, 13 E350 AMG, 11 Ford F350
Have you considered bleeding the brake system first? Just a thought.
I bought the diamonds myself so I would not have to say thank you to anyone.
Old January 25th, 2005, 12:52 AM
The booster or the valve is bad. Or the line popped off etc.
This is a booster/vacuum issue.
The only other thing would be a seized bearing on the shaft but this is extremely unlikley.
Old January 25th, 2005, 05:14 AM
Vadim
vadim
95 D90
So you think it is booster? How I can check it? Somehow I can hear when I step on the brakes,how mine rear brakes it's working,but not front brakes.I think this is weird .
Thank you
Vadim
Old January 25th, 2005, 07:58 AM
So if you press real hard do the rears lock up and the fronts do nothing? Maybe the proprtioning valve (not sure what it is called but it sends break pressure front and rear so that you yuo aply more to the front then rear) is broken.
Old January 25th, 2005, 08:36 AM
rolaro
Jan-Dirk Roodbol
1985
Vadim,
I send you an e-mail with, I hope, the right info.
copie's from a Haynes manual how to check the booster.
If you have only brakes on the rear, earlier models have a so called PDWA valve; if there is a leak in the front part of the sytems, a safety valve blocks the part automatically. I'am not sure if youre truck has this part in it.
cheers
Old January 25th, 2005, 01:09 PM
Vadim
vadim
95 D90
Thank you to everybody,I guess I wil spend my entire weekend under car )Better than rearend somebody on hwy
brake
Hard Brake Popping Jon_Winningham Defender Technical Discussions 8 December 22nd, 2006 12:15 PM
Hard brake lines! TwisteD90 Defender Technical Discussions 10 October 10th, 2005 12:12 PM
Hard Top for sale Mark Cama For Sale - Parts 0 August 31st, 2005 09:19 AM
brake pedal mattdh Defender Technical Discussions 1 February 12th, 2005 05:35 PM
need wobbly brake pedal advice. januconn92 Defender Technical Discussions 6 May 24th, 2004 04:13 PM
