brake pedal - Defender Source
Old February 12th, 2005, 04:19 PM
mattdh's Avatar
mattdh
Matt Hurst
brake pedal
just bled the brakes-would like to know about others since i have not used the brakes on this thing for over 2 years-the pedal depresses about an 1 and 3/4 inch -is this about what it should be?thanks for the info.
Old February 12th, 2005, 05:35 PM
Hmmm, drive it around the block and if it stops your good. I have been in a few and they all have there stop point, if there is still travel left then you should be ok.
brake
Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest Buckon37s Defender Technical Discussions 223 September 1st, 2014 01:49 AM
Bling - Billet aluminium pedal covers Defender50th Misc. Chit-Chat 2 April 26th, 2005 03:30 PM
Brake pedal is hard!!?? Vadim Defender Technical Discussions 9 January 25th, 2005 01:09 PM
need wobbly brake pedal advice. januconn92 Defender Technical Discussions 6 May 24th, 2004 04:13 PM
