Brake pad wear? - Defender Source
Old March 15th, 2010, 09:12 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
Brake pad wear?
Just went in for the BS Pa. yearly inspection. the said all my inner pads were wearing more than the outside pads. Is this a normal Land Rover thing or are my calipers going bad?
Old March 15th, 2010, 09:26 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
They should wear close to normal, but there may be some variance. If it's not too serious of a difference, I'd think there might be some air in the outer half of the calipers. If it's a big difference, it might be time to rebuild the calipers.
-Hans
My oil line fix
My 100k stopped odometer fix
brake
Warn 8274 brake pad relacement? Hammertime Defender Technical Discussions 4 September 8th, 2009 10:05 PM
1984 110 front brake pad part #? tommyd Defender Technical Discussions 0 July 21st, 2009 04:37 PM
brake pad anti rattle coil type springs. thewap Defender Technical Discussions 2 August 20th, 2006 09:56 AM
Brake Rotor wear Eric Siepmann Defender Technical Discussions 1 October 1st, 2004 11:42 AM
