Brake Pad Clunking Noise - Page 2 - Defender Source
Old April 15th, 2011, 08:54 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
One solution is to swap your motor for a TDI, the sound will magically disappear.
Seriously, what would concern me is that you are describing the sound as "clunking" and after the brakes have been applied and released. I wouldn't be 100% on that being the pads, although the description of the sound is somewhat relative so it could be. Those pads are designed to have some play and they must have it. I wonder if the rotor replacement has something to do with this.
Old April 15th, 2011, 10:14 AM
hutch's Avatar
hutch
Hutch
97 AA Yellow D90 ST
Well part of me says it's a D90 what do I expect! So true to your point on general noise... I don't believe this is s safety concern - it's more being nailed by the dealership. I've paid a premium therefore I want it done right - period. I do think the rotors are hitting the brakes when they aren't applied causing this and they probably just jammed something against the pad this time hoping I wouldn't notice. It's quieter this time around - when I pull off the wheel this weekend I'll take a look and see what they did. We'll see. It's always something.
-h
Old April 15th, 2011, 11:38 AM
carlosz's Avatar
carlosz
Carlos
check bearing end play,.. land rover does not support vehicles older than 5 yrs, has not done so since 2000, hence the lack of tecks properly trained to work on older trucks.
Old April 15th, 2011, 11:44 AM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
I can't believe this problem has not been solved yet....Stealership! While you are in there, check the two caliper mounting bolts and make sure they are tight. This could also cause these symptoms.
Old April 15th, 2011, 12:13 PM
DNinety's Avatar
DNinety
JP
1984 Ninety 200TDI
Update: I just watched your video and that answers the question I had (now erased).
Old April 15th, 2011, 05:40 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi hutch, i swapped my rotors out cured the warp but now both sides clunk.. ! arse.
however i have cured a clunk on my mates td5, same situation as yourself he had the vehicle serviced which included new pads all round about a week later he noticed them clunking when rolling to a stop.
he took it back to the garage and they said it was normal.!
though they did remove the pads & re coat the back of the pad with copper grease, this stopped it for a few days then clunking restarted.
I had a look and sure enough the pad is moving forward in the calliper and hitting the leading edge, I cured it by fitting a set of ferodo brake pads bought from the local motor factors.
these pads had a soft pad stuck to the backplate i fitted them dry & pressed the brake hard to set the piston into the soft backing took it for a run...no clunk!
I saw him tonight and its still clunk free a week later, I'll buy a set for mine tomorrow and see if i can fit them sunday.
you can see the backing pad on the brake pad on their home page:http://www.ferodo.co.uk/ferodo_web/about-us.aspx
regards all
Gren
Old April 15th, 2011, 06:10 PM
kevkon's Avatar
kevkon
kevin
Are you taking about the Thermoquiet pads?
Old April 16th, 2011, 05:00 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
No they were just the standard ferodo pads for the td5.
Today I bought a set of pads for mine, the local factors were out of ferodo but I bought a set of Delphi
pads that looked the same and fitted them earlier today after a 50 mile run no clunk.!
I'll post pics later
regards
Old April 17th, 2011, 01:27 PM
hutch's Avatar
hutch
Hutch
97 AA Yellow D90 ST
I think this is the issue - going to pop off the wheel today. They stand by that they are going to solve it for me - they better it's getting annoying. They say the pads are about 1/8 of an inch too small so they are moving and the pin is too small as well. They are going to try aftermarket and measure the next set. We'll see.
Old April 17th, 2011, 05:08 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi hutch I doubt its the calliper bolts easy to check anyway.
100 miles in and my clunk is gone after replacing the original pads they only had 6K miles on them and were noisy from the start.
now i can cruise slowly, checking my reflection in shop windows with only the gentle tinkle of the tdi and flap of the ST.
regards
ID:	37944   Click image for larger version
ID:	37946   Click image for larger version
Old April 18th, 2011, 08:55 AM
hutch's Avatar
hutch
Hutch
97 AA Yellow D90 ST
Thanks for the photos - helpful to compare. Dumb question... these are the new pads in the photos I'm assuming? So you have no vertical play with the new set up? Or is it just minimal? I have too ,much play:
Yesterday came and went and I didn't have time to work on the truck. (Also my jack is leaking oil and I'm a bit worried to use it!) One evening this week I'll take a look top-down and rule out the bolts.
sorry to drag this thread out but the advice is appreciated. Hopefully there will be a positive resolution to this annoyance...
That's pure poetry! I think I shed a tear...!
One day soon that will be me. Until then I hear a CLUNK!! CLUNK!! and the whine of the bearings in my alternator about to explode.
-h
Old April 18th, 2011, 06:44 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
In the pics with the 3 pads the new one is in the middle you can see the circles from the pistons in the grease on the backplate of the old ones.
yes i have a small amount of play in the pad but it now does not clunk i think the backing pad stops the pad slipping past the pistons and hitting the leading edge of the calliper, don't know if the chamfer on the pads helps any.
I waxed the beast (not a euphemism for my gristle stick or my wife.!) yesterday and she looks great in the shop windows .. shame the driver looks like Frankenstein's ugly twin
regards all
Old July 15th, 2011, 08:20 PM
hutch's Avatar
hutch
Hutch
97 AA Yellow D90 ST
Just a follow up here...
The dealer ended up installing after market pads and they sit nice and tight. The clunk is gone.
Apparently the pads ordered by the dealers are simply not manufactured properly anymore. These were a 1/8" wider and fit perfectly.
-h
Old July 15th, 2011, 10:02 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
I think you'll find the genuine pads fit really nicely in a new caliper. Some aftermarket pads are really hard to get into a new caliper as they are too big. I've had to file pads to get them to fit into new calipers correctly.
Matt Browne
brake
Brake/Friction Pad (and maybe Brake Disc/Rotor) Replacement rijosho Defender Technical Discussions 62 March 16th, 2011 03:55 PM
Brake Pad Install moose Defender Technical Discussions 1 June 27th, 2010 10:54 PM
Warn 8274 brake pad relacement? Hammertime Defender Technical Discussions 4 September 8th, 2009 10:05 PM
brake pad anti rattle coil type springs. thewap Defender Technical Discussions 2 August 20th, 2006 09:56 AM
Brake Clunk--Clank RoverChic Defender Technical Discussions 11 December 30th, 2004 04:17 PM
