brake pad anti rattle coil type springs. - Defender Source
Old August 9th, 2006, 11:08 AM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
When I changed to DBA rotors and replaced the pads, the new pad install kit had the coil type anti rattle spring that the pad pins go thru. (my old springs were the plate type that fit under the pins and push down on the pads).
Does anyone notice that the coil spring type is junk?. Doesn't stop the pads from rattling up and down at slow speeds.
(as in my case). No such problems with the plate type. Slight squealing when I just come to a full stop, and rattling at slow speeds. Wonder if the rattle springs could make a difference to others who have had problems with squeal on DBAs.
Old August 20th, 2006, 09:19 AM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Mine has the coil springs. Had a problem with the rattling at low speed too. I just streched the coil springs out a little and it hasn't rattled in 30k miles.
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
Old August 20th, 2006, 09:56 AM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
Great info. Gonna try the stretching program. Thanks
Marc
brake, coil, rattle
Brake Rattle Pins Robbie Donaldson Wanted 0 November 13th, 2009 11:36 PM
Warn 8274 brake pad relacement? Hammertime Defender Technical Discussions 4 September 8th, 2009 10:05 PM
Rear Coil Springs for 110 Santiago Defender Technical Discussions 6 January 17th, 2008 12:28 PM
Need Help with Springs for an 88 Coil Truck TDI Guy Defender Technical Discussions 11 June 6th, 2006 06:55 PM
Front shocks outside of coil springs? castlerock4x4 Defender Technical Discussions 19 May 12th, 2004 04:23 PM
