Brake Master Cylinder Rebuild HELP - Defender Source
Old August 4th, 2006, 05:35 PM
Heath's Avatar
Heath
Heath Ahrens
1995/D-90
Question Brake Master Cylinder Rebuild HELP
I got a kit a while back and finally got around to pulling out the Master Cylinder (of course right before I go on a trip). Guess what??? I thought I put everything back exactly as before but apparently not.
Does anyone have any sort of diagram or pic for putting the seals on the master cylinder?
I am kinda screwed.
Old August 7th, 2006, 09:38 AM
Should be one in the box for the rebuild kit (there was with mine but it is long gone now). I would google or call/email lucas/girling or roversnorth. They should have one.
Old August 7th, 2006, 05:11 PM
Heath's Avatar
Heath
Heath Ahrens
1995/D-90
I realized the problem was part of it was in backwards...
I also realized that my master cylinder was fine (and thankfully still is)...
I need a new servo (power brake). There is hot air blasting down through the brake pedal. I wonder if that is supposed to happen or if it is part of the servo being bad. The truck stops, but only with two feet on the brake trying to push it thought the floor. There is a little bit of help from the truck running, but it is hard to push the pedal more than a few inches.
brake, master, rebuild
Clutch master cylinder replacement Trigger Defender Technical Discussions 20 July 8th, 2015 08:01 PM
Clutch Master Cylinder Billakris Defender Technical Discussions 22 November 29th, 2011 03:02 PM
Brake Master Cylinder Leak chris snell Defender Technical Discussions 12 September 28th, 2011 09:50 AM
8274 Brake rebuild Red90 Defender Technical Discussions 4 October 4th, 2005 10:52 AM
NEW Clutch Master Cylinder 4 Sale roverboy For Sale - Parts 0 October 6th, 2004 10:10 PM
