brake lines on a D110 non-abs master cylinder - Defender Source
Old July 7th, 2015, 11:51 PM
cdb
Clark Bowen
I'm converting my Series 2a 88" to disc brakes using a D110 master cylinder (NRC9529) that has a 12mm brake line opening towards the front of the vehicle and a 3/8" unc closer to the servo.
This master was designed for a D110 with front discs and rear drums which is what the 88" will have.
So, who gets the larger opening (12mm) - front discs or rear drums?
Thanks from the totally confused
2011 RR HSE -
2001 GMC 2500 4wd
110, brake, d110, master
Abs vs non-abs swivel pins jafir Defender Technical Discussions 6 October 14th, 2014 08:24 PM
ABS CVs fit in non ABS car? sflash868 Defender Technical Discussions 2 July 21st, 2014 06:55 AM
Brake Master Cylinder Leak chris snell Defender Technical Discussions 12 September 28th, 2011 09:50 AM
Brake Master Cylinder Rebuild HELP Heath Defender Technical Discussions 2 August 7th, 2006 05:11 PM
Re-Sleeve ing Rear Brake and Clutch Master Cylinder COSteve Defender Technical Discussions 12 June 24th, 2006 12:33 AM
