brake line patching - Defender Source
Old July 23rd, 2009, 04:52 PM
brake line patching
Ok so I was going to JB weld the broken brake line --- kidding.
Where can I buy the proper flare tool and a piece of line about 6in long and all the ends I need? I assume I cannot use the stuff I see at pep boys, right?
Old July 23rd, 2009, 04:57 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
These guys carry everthing. http://www.fedhillusa.com/
Old July 23rd, 2009, 04:58 PM
Thanks Kevin, but they get $360 for the tool which is insane.
Old July 23rd, 2009, 05:04 PM
61rover's Avatar
61rover
John Crouse
I got the flare tool at Checker Auto and bought a small tube cutter at Home Depot. The line is available any NAPA or most any decent auto parts store.
I busted a rear line on the rim of the Grand Canyon last week. The NAPA in Kanab, UT had the line. The line rusted through under the little strap bracket.
Old July 23rd, 2009, 08:04 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
I've got pre-bent lines if you want to just cure the problem for good.
Email:
Old July 23rd, 2009, 09:22 PM
Thanks for the offer Mike.
I have a complete 110 set from classic tube and I ordered another set and I will replace it when I take the body off, I just want to get it moveable for the moment and the leak is easy to cut the bad part out now and if replacing that line that runs on top of the frame is as bad as on a RRC then I prefer not to do it now.
Ron
Old July 23rd, 2009, 09:34 PM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
My local NAPA store carries the double flaring tool -- $40 give or take $10, as I recall.
John Karlsson
Hope Valley, RI
Old July 23rd, 2009, 10:57 PM
John, I will call NAPA in the am. Their driver has figured out how to drop off parts/supplies at a law firm.
Old July 23rd, 2009, 11:20 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Old July 23rd, 2009, 11:44 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I was just pointing out that they have the proper fittings. You can rent that tool for 25 bucks a week, which is pretty good after my experience of making loads of crappy double flares one after the other with a 40 buck tool.
Old July 23rd, 2009, 11:46 PM
Screw it, I will just replace the whole line. Now I need to find some brake clips and will probably break off the end that goes to the flex pipe in the rear, but at least I have a spare flex line too. UGH.
Ron
Old July 24th, 2009, 07:02 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
You don't want a double flare tool, you want a bubble flare tool. OTC makes one that works well. So does KD I think, or maybe Lisle, but I have the OTC tool.
Summit Racing has a decent price on it. OTC-4504
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old July 25th, 2009, 01:00 PM
Rocketman's Avatar
Rocketman
Scott Y
95 D90 SW, 2003 Disco II, 93 D110
Ron,
I bought the tool from fedhill along with some of their tubing. After buying the flaring tool, and it is really a beaut, I saw they had something similar for a lot less from Eastwood. That said, the FedHill tubing is beautiful to work with and they have all sorts of fittings -- metric, SAE, ISo bubble, double flare, etc. Also, their flare tool has a large number dies available for several size tubing, just in case you want to do say fuel lines...
I have rebuilding the brake system on a 1970 italian car--has girling brakes which requires the 3/8-24 in fittings.
Old July 25th, 2009, 10:45 PM
Thanks guys. I went out to the garage and the only line I was able to save from the last one I took apart was, believe it or not, that line so I replaced it with that used line to get her moving. Everyone else would have thrown out that line. I will order another full SS set from classis tube in the future. It was not too bad to do with all the floors out.
brake
Brake line upgrades - what/where to buy? pmd Defender Technical Discussions 11 March 30th, 2007 11:58 PM
Brake Line ? RoverChic Defender Technical Discussions 18 March 5th, 2007 05:45 PM
Brake Line whistler110 Defender Technical Discussions 2 November 25th, 2006 08:18 PM
Line Lock for Winch Line Maine 110 The Vendors Loft 6 February 7th, 2006 06:47 AM
brake line connections artm Defender Technical Discussions 0 May 7th, 2004 02:04 PM
