Brake line fitting size and thread - Defender Source
Old March 3rd, 2012, 10:11 AM
Chris Velardi's Avatar
Chris Velardi
Chris Velardi
1975 101FC
Replacing the entire front brake set up on the wife's '85 110. Putting on the Defender 90 calipers and vented rotors ( all bolt up . as a mater of fact if your old 110 front rotors are still good and your just replacing the frozen calipers you can get the D90 calipers and remove the 3/8" spacer that is sandwiched between both sides or the D90 caliper and it will fit the old 110 non vented rotors) but while I'm at it I'm going to make up some new Poly-armour coated brake lines to the front calipers. Does anyone know the proper fitting type and thread type that are the jump lines from the Axel to the calipers ?
Chris "V"
Old March 3rd, 2012, 10:46 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
I would bet m10x1.0 iso bubble flare
Old March 4th, 2012, 03:49 PM
Chris Velardi
Chris Velardi
1975 101FC
I believe so , has anyone noticed a difference between "British" 10 x 1. thread and "European" thread ? one of the local auto parts stores had them marked as European and they thread felt like it had less slop than the British 10x .1 that I have
Chris "V"
Old September 30th, 2013, 11:30 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Reviving an old thread here...
I am planning to make all new brake lines for the 110, but I am starting to see some contradictory info in different places. For what it's worth, I am swapping to Discs in the rear as well.
I am trying to find out definitively what type of flares are used where and what type of fittings. My understanding is that the entire system uses ISO Bubble Flares with M10x1.0 Fittings, but are the flares at the Calipers and Master Cyl the same as well?
What about the Clutch, does anyone know the size and type of those fittings/line?
Thank you!
Old September 30th, 2013, 12:06 PM
Calipers are m10x1 DIN flare. So are the T fittings on the rear for both the flex line and the hard lines. Ditto the proportioning valve and whatever other weirdness you have between the master and the calipers.
Master Cylinder is, well, various depending on the type of MC you have. Need a pic if possible.
Clutch is 7/16-20 Girling for 1/4 inch pipe with SAE flare, I think. If you have the adapter fitting on it then I think that's M12x1.0. I know I used DIN flares on the slave, and SAE flare on the master, with no adapter. I think the flex line is also 7/16-20 Girling and you need the long cone type female nut.
Old September 30th, 2013, 01:08 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Thanks, I'll try to take a picture later today. So the brake lines are all 3/16 with M10x1.0 fittings and DIN Flares? I purchased Stainless Braided Flexible lines, so I don't need to make those, I just want to make sure I order the right Fittings and lines to make all the hard lines myself.
I will take a pic of the MC and Clutch/Slave later. Thank you!
Old September 30th, 2013, 01:12 PM
Yes, except for the nuts on the Master Cylinder.
Old September 30th, 2013, 01:17 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I've seen reports from people about the poly coated brake lines de-laminating and rusting where you can't see. I prefer the copper/nickel like from Fedhill or NAPA.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old October 22nd, 2013, 11:40 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Ok, here are some pics of the MC
ID:	82665   Click image for larger version
ID:	82667   Click image for larger version
Old October 22nd, 2013, 12:03 PM
Those are 10mm DIN flare. The early cast iron MC has 10mm and 12mm nuts.
Old October 22nd, 2013, 12:04 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Great, Thanks! I need to get a quick pick of the Slave as well, will do that soon.
Old September 7th, 2014, 10:18 PM
How much brake line is needed for a 110?
Originally Posted by pendy
I'm here for the D's
Old September 7th, 2014, 10:34 PM
And I guess if anyone knows the rough count of how many male and female connectors one would need to completely do the brakes from scratch. As well as tee's? Anything else I should order from fed hill while I'm at it?
charles
Old September 7th, 2014, 10:52 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Originally Posted by cgalpin View Post
And I guess if anyone knows the rough count of how many male and female connectors one would need to completely do the brakes from scratch. As well as tee's? Anything else I should order from fed hill while I'm at it? Thanks, charles
your gonna need at least thirty feet of line, and about a half dozen female connectors and a dozen males. Don't quote me, we just did the lines on that 90 and it took a couple hours. We reused most of the original connectors, just cleaned and polished before we flared. FYI make sure you double flares on the females and bubble flares on the makes.
Old September 7th, 2014, 10:59 PM
Thanks!
Old April 12th, 2016, 01:28 PM
DailyDrivenDefende
Michael
1989 110, 1985 90 200TDI
Thanks!
Charles, how many of each components did you end up buying?
Old April 12th, 2016, 06:41 PM
Michael, believe it or not I have not plumbed it up yet. Hopefully in the next few months
I forget how much I bought, but will check. I do know the fittings I bought didn't fit my calipers so I picked up some more when I was in the UK, but can't recall the count of those either, but will see what I have too.
Old April 12th, 2016, 07:22 PM
I bought 2 x 25' lengths of line and 10 each of the male and female connectors. Hoping that's sufficient.
Old April 12th, 2016, 07:42 PM
DailyDrivenDefende
Michael
Where can I order some of these in US?
Old April 12th, 2016, 08:03 PM
I got the line from fedhill, but like I said the fittings didn't match. I suspect any of the vendors can get you the right ends (and line too).
brake
300 tdi oil cooler fitting thread size Overlander Defender Technical Discussions 8 September 16th, 2011 12:34 PM
thread size snuffer Defender Technical Discussions 0 October 26th, 2005 08:24 PM
Rollcage light tab thread size read Defender Technical Discussions 4 January 28th, 2005 02:33 PM
Transfer Case Lever Thread Size? ronward Defender Technical Discussions 4 August 30th, 2004 02:26 PM
Thread size for temp sender mgrgpg Defender Technical Discussions 3 July 1st, 2004 12:00 PM
