Brake line fitting size and thread - Page 2 - Defender Source
Old April 12th, 2016, 08:52 PM
bossman429's Avatar
bossman429
Adrian
1988 90
I'm going to do all my lines with DIN flares. About 10x the selection from vendors (jegs etc). Obviously certain components will need to match (MC CALIPERS etc)
Old April 13th, 2016, 07:45 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Originally Posted by cgalpin View Post
I got the line from fedhill, but like I said the fittings didn't match. I suspect any of the vendors can get you the right ends (and line too).
Fedhill is a great place to get lines & fittings... they also rent flaring tools and have a lot of tech info.
Old August 26th, 2017, 11:19 PM
BlackField's Avatar
BlackField
Oscar
D110
What's the length from axle to each flexible caliper hose front L/R and rear L/R? These are all M10x1 female at the axle end? I'm using banjos for the non OEM calipers.
brake
300 tdi oil cooler fitting thread size Overlander Defender Technical Discussions 8 September 16th, 2011 12:34 PM
thread size snuffer Defender Technical Discussions 0 October 26th, 2005 08:24 PM
Rollcage light tab thread size read Defender Technical Discussions 4 January 28th, 2005 02:33 PM
Transfer Case Lever Thread Size? ronward Defender Technical Discussions 4 August 30th, 2004 02:26 PM
Thread size for temp sender mgrgpg Defender Technical Discussions 3 July 1st, 2004 12:00 PM
