Brake Line Clips on Bulkhead - Defender Source
Old June 15th, 2012, 09:11 AM
Lesandjes's Avatar
Lesandjes
AndrewT
'93 NAS D110
This may be the most inane help needed post ever.
Did bulkhead swap on my NAS D110 and got new plastic brake line clips that mount on the bulkhead as the old ones broke when they were removed (which is how they are designed).
So the new ones look identical but I cannot tell how they are supposed to stay into the holes in the bulkhead:
- they are too big to fit in hole so I either need to widen hole in bulkhead or sand down the plastic clip
- there is no obvious way it will stay in there (is it supposed to be glued there?)
Thoughts? Pic shows the old one (that broke after removal) and new replacement clip.
AndrewT
'93 NAS D110 #437
brake, clips
Front brake line - why hard line & flex line? jefhuf Defender Technical Discussions 5 January 13th, 2012 09:03 AM
Standard vs. Metric Brake Line? founD90 Defender Technical Discussions 7 July 19th, 2010 05:02 PM
Brake Line ? RoverChic Defender Technical Discussions 18 March 5th, 2007 05:45 PM
Brake Line whistler110 Defender Technical Discussions 2 November 25th, 2006 08:18 PM
brake line connections artm Defender Technical Discussions 0 May 7th, 2004 02:04 PM
