Brake Line - Defender Source
Old November 25th, 2006, 03:49 PM
whistler110's Avatar
whistler110
Mike Johnstone
ex-mod 110
Brake Line
This may be a stupid question but is there a reason for running the small hard brake line on the front calipers after the rubber line? I am constantly fighting corrosion with all the salt used on the roads up here and I had to replace one of these small lines again last night when I removed the caliper to repack the hubs.
Does this line just keep the flex line away from the tire? Is it an attempt to run less flexible rubber? I'm wondering if it would be easier to run SS braided from the hard line at the shock tower directly to the caliper.
Bike Mike
Old November 25th, 2006, 08:00 PM
No, and there are places in the UK that make SS lines direct.
On another point, there is no reason to disconnect the brake lines when working on the hubs. Just unbolt the caliper and hang it off to the side with something.
Here is a thread, see post 25
Old November 25th, 2006, 08:18 PM
whistler110
Mike Johnstone
ex-mod 110
Thanks for that.
I replaced the line because it broke at the bend behind the caliper. The line must have been hit by me or something else at some point and kinked. I tried to pursuade it back a little to see how bad the kink was but it snapped. The line was half rusted through anyway so it was probably a good thing.
Bike Mike
brake
brake line patching evilfij Defender Technical Discussions 13 July 25th, 2009 10:45 PM
Brake line upgrades - what/where to buy? pmd Defender Technical Discussions 11 March 30th, 2007 11:58 PM
Brake Line ? RoverChic Defender Technical Discussions 18 March 5th, 2007 05:45 PM
Line Lock for Winch Line Maine 110 The Vendors Loft 6 February 7th, 2006 06:47 AM
brake line connections artm Defender Technical Discussions 0 May 7th, 2004 02:04 PM
