Brake Ligth Flicker - Defender Source
Old October 19th, 2009, 02:57 PM
bjf's Avatar
bjf
barry f
94 ST #395
Brake Ligth Flicker
The brake light in my 90 has been flickering lately. I think I need pads. Does this thing actually serve as a warning light?
Old October 19th, 2009, 03:22 PM
I think it did on some of the Range Rovers and Discos. Mine would blink when my fluid level would get low,I am not sure of the differences between the 90 and the 110..
Old October 19th, 2009, 03:24 PM
Pads wear, which makes the pistons extend out further which drops the fluid level which triggers the light. Check your pads to see how low they are. There are not sensors on the pads.
Old October 19th, 2009, 04:09 PM
Lesandjes's Avatar
Lesandjes
AndrewT
'93 NAS D110
Or you just need to add brake fluid. If its already at the FULL line, Fill it a little above the FULL mark on the reservoir and see if it goes away.
AndrewT
'93 NAS D110 #437
Old October 19th, 2009, 04:14 PM
bjf's Avatar
bjf
barry f
94 ST #395
I figured I needed pads.
So annoying. More money to spend
Old October 19th, 2009, 05:13 PM
Jon_Winningham's Avatar
Jon_Winningham
Sterling M Archer
1995 AA Yellow NAS D90 #2986
Be sure to clean the two little brass plugs and ring that is in the cap of the break reserve. If they are corroded then your light will flicker.
Old October 19th, 2009, 10:52 PM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
Could the flicker be from a short in the wiring?
Same thing just started happening to me. I had my front brakes replaced less than 1000 miles ago.
Old October 19th, 2009, 11:26 PM
bjf's Avatar
bjf
barry f
94 ST #395
Yeah I have heard it could be that too. At last check I was at 40% front and 30% rear or something like that so I assumed I was due.
Old October 19th, 2009, 11:49 PM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
There is another thread titled something like "should I be worried"
discusses removing the emergency brake boot and cleaning the wires.
I'm going to check that as soon as I can get home before dark or this weekend. It's annoying but dealable till then
Old October 20th, 2009, 06:00 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
That happened to me and all that was wrong is that I was low on brake fluid. I topped it off and the light went off.
Old October 20th, 2009, 11:01 AM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
Okay
I'll check the brake fluid level also.
Looking at other threads on brake fluid says to use Catrol GT LMA (Should have a minimum boiling point of 500 degrees F.)
If I can't find that, will any DOT4 with minimum boiling point brake fluid suffice?
How can I tell if what's in my D90 is mineral oil or synthetic?
Thanks in advance.
Old October 20th, 2009, 12:05 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Trouble is, when "topping up" the brake fluid, when you come to change the pads and push the pistons back in.....
....all the extra fluid overflows from the reservoir over your paint.
far better to check the pads first.
brake
brake light switch snuffer Defender Technical Discussions 7 March 28th, 2006 07:02 AM
Clogged brake lines? Heath Defender Technical Discussions 11 February 24th, 2006 08:39 AM
Emergency Brake Issues Ragland Defender Technical Discussions 10 April 7th, 2005 07:09 PM
