Brake Lights Stuck ON - Defender Source
Old August 20th, 2004, 04:19 PM
RoverWrecks
M R
I recently had the fun experience of not being able to shift from park to drive. Well, I replaced the switch and now I can shift with no problems, but the brake lights are on permanently. Anyone else had this problem?
Tonight I plan on reseating them to see if that resolves it.
Also does anyone have the schematic for the fuse panel for a 97 Disco? Mine of course was kept by the previous owner.
Old August 20th, 2004, 09:03 PM
RoverWrecks
M R
Well I reseated it and they are still stuck on, funny thing is that when I depress the switch, it locks the shifting and I assume since no one is behind me that the lights go out. It's operating oppsite. Go figure.
Old August 20th, 2004, 09:28 PM
ronward's Avatar
ronward
Redsrover
None - sadly
You might have the brake light switch wired backwards. Not sure on a Discovery.
Old August 21st, 2004, 08:09 AM
RoverWrecks
M R
I had thought so too
But the way it's setup it only plugs in one way, but worth a harder look.
Old August 21st, 2004, 11:26 AM
robheath
robert heath
i dont know about disco's but on defenders the brake switch behind the servo is very dodgy and mine goes quite often it might be worth a look
brake, ht, lights
No brake lights! Need help. durangorover Defender Technical Discussions 10 September 30th, 2011 11:18 PM
Left brake lights work....the right and door brake lights won't? beko35 Defender Technical Discussions 4 June 27th, 2009 02:12 PM
Help!!! State Inspection No brake lights !! Hammertime Defender Technical Discussions 11 February 10th, 2008 08:09 PM
weird brake lights sflash868 Defender Technical Discussions 4 April 17th, 2006 11:37 PM
