Brake light switch replacement / diagram? - Defender Source
Old April 16th, 2011, 10:00 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Finally got the new clutch master cylinder installed today. Opted to pull the whole bracket assembly to take care of any surface rust on the firewall. To do that, had to dismount the brake box too, for clearance.
Anyway, while I was doing that, I busted off the brake light switch, need a new one. Just wanted to check on how it installs though, before I go too crazy.
Any nut or retainer inside the servo housing at all? Or does it just thread in from the backside of the brake servo housing?
-Hans
My oil line fix
My 100k stopped odometer fix
ac, brake, ht, switch
brake light switch snuffer Defender Technical Discussions 7 March 28th, 2006 07:02 AM
Main light switch jchan88 Defender Technical Discussions 3 November 13th, 2005 09:43 PM
tire carrier, 3rd brake light, and other stuff jabber For Sale - Parts 12 January 20th, 2005 03:06 PM
