brake light switch - Defender Source
Old April 13th, 2004, 09:54 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
brake light switch
How can you get to the brake light switch?
Does it work off the brake pedal. I can't see it from the inside of the footwell, but I'm not quite as flexible as I used to be.
Any other ideas why the brake lights are on all the time. I just rebuilt my clutch master cylinder but didn't see any kind of switch on the engine side of the bulkhead.
Old April 14th, 2004, 12:41 AM
wicks's Avatar
wicks
Wicks
97 Defender LE SW #44
It's tucked away behind the bonnet to bulkhead lip, on the backside of the brake housing (from under bonnet). Feel around there for the wires and you'll find it. Mine went last year.
Old April 14th, 2004, 12:53 AM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
da las gracias mi amigo
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
Old April 14th, 2004, 04:20 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Thanks again Wicks, I found it and I guess while doing the clutch master cylinder I got the switch in a bind and broke the plastic threads.
Old March 21st, 2006, 07:37 PM
dfscott
Daryl Scott
1994 Defender
I recently replaced my brake light switch (pain to get at). My brake lights now work fine when I press the brake pedal. The problem however, is that the car feel as though either the brake pedal or parking brake is still engaged. I disengaged the parking brake and the brake pedal doesn't feel unusual or out of position. Is there an adjustment that should be made to the brake light switch?
Old March 22nd, 2006, 05:15 AM
ne4x4's Avatar
ne4x4
Ian McCormack
1984 Landrover 90
yes it should only be screwed in far enough so that the lights go out then locked with the lock washer, if its screwed all the way how it will be partially pressing the brake pedal
Old March 23rd, 2006, 08:13 PM
dfscott
Daryl Scott
1994 Defender
Ian: I adjusted the brake light swith and it works fine. It's nice to have brake lights again. However, the brake is still partially engaged when the car is moving. Any other suggestions?
Old March 28th, 2006, 07:02 AM
ne4x4's Avatar
ne4x4
Ian McCormack
1984 Landrover 90
strange one, sounds like a barake piston sticking. Just a daft thought though, the end of the old brake light switch, did it brake off and is it wedging the pedal, if not then it has to be a sticking brake piston or the wrong brake light switch.
As a starter for 10 unscrew the brake light switch and see if the problem goes away
brake, ht, switch
Tailgate, Tire Carrier, 3rd Brake light, rear bumper jabber For Sale - Parts 5 December 8th, 2005 02:10 AM
Main light switch jchan88 Defender Technical Discussions 3 November 13th, 2005 09:43 PM
tire carrier, 3rd brake light, and other stuff jabber For Sale - Parts 12 January 20th, 2005 03:06 PM
