Brake light question NAS 110 - Defender Source
Old April 30th, 2014, 07:25 PM
emah's Avatar
emah
Ed Mah
1993 NAS D110
Hello, searched archives and no luck. I recently acquired a NAS 110 and found out that the three rear brake lights do not work. Ive checked the bulbs and wiring on rear lights and 3rd light and it looks fine. Any suggestions what else I should check that may be causing the lack of connection? Anything above brake pedal that I should check? Thanks in advance!
Old April 30th, 2014, 08:13 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
You have a switch on the brake box, firewall side. It is hard to get to. It will have two connectors going to the switch. It screws in as the adjustment. I would also double check the fuses and the fuse box to make sure you have a good fuse and connection. On the engine side of the bulkhead you also have the chassis harness connection. I would check that to make sure the wires are connected and good.
Old May 1st, 2014, 12:54 AM
3rovers's Avatar
3rovers
Dennis Yard
1993 NAS D-110 #55
Eddie,
All the rear brake lights are on the green and purple wires coming out of the chassis harness and back into the rear crossover harness. Behind the right rear speaker is where the harnesses come together into the cabin. They are all connected to each other in the multiple bullet connectors.
Additionally, I found that the four or five separate lamps in the window mounted third brake light were loose in their individual sockets. I had to pull/push them in and out a couple of times to clean up the sockets a bit and I also brushed off the individual socket lugs to make them shiny.
See my post from a few days ago about solving a misreading fuel gauge by cleaning some of the connectors and especially cleaning and rebonding the black ground wires of the harness.
Optionally, maybe we can get together at your place of work over the weekend and I can point out the areas to work on.
Cheers,
Dennis Yard
Land Rover Club of San Diego
1993 NAS D-110 #55 (GNUTRUK)
2004 Disco II (DSCO DOG)
Old May 1st, 2014, 01:49 AM
emah's Avatar
emah
Ed Mah
1993 NAS D110
Thanks!
Thanks Mike and Dennis. I will check the harness out tomorrow. The fuses looked good. I'm just not sure what the harness looks like or where it is from you description.
Dennis, maybe we can meet up this weekend. I'll be in touch.
Thanks guys and I will update what I find out.
Eddie
110, brake, ht, nas, nas 110
Parking Brake and Rear brake light gas-man Defender Technical Discussions 9 February 20th, 2012 11:40 AM
WTB - Defender Third Brake Light Bar w/light paydan Wanted 0 December 1st, 2011 02:28 PM
Rusty soft top third brake light bar and light evilfij Wanted 2 May 20th, 2009 11:26 AM
Brake Light Question waveridin1959 Defender Technical Discussions 6 May 4th, 2005 02:42 AM
Brake light on after brake install wicks Defender Technical Discussions 6 October 13th, 2003 07:01 PM
» Defender Registry
Deffy
fuff12000
Oliver
IvanKV
Add your Defender
