Brake light issue - Defender Source
Old October 17th, 2013, 11:58 AM
JBOD77
Jonathan
1995 D90 ST Beluga Black
Brake light issue
Driver's side brake light does not light up. the running light works but when you apply the brake the lamp goes out completely instead of getting brighter. Also the high stop light doesn't work i imagine somehow that's tied into the driver's side light? Passenger side functions normally.
Any ideas as to were to start?
Thanks in advance
This is where I'm supposed to write something witty and funny; or something.
Old October 17th, 2013, 12:28 PM
Mine was a shorted wire in the back. It's pretty easy to check from behind the rear wheels, so I'd say start there and confirm the integrity of the wiring back there. If you're running the stock 1995 lights, then also open up the lights and check the connection at the plinths for corrosion. Work from where it's easiest to access first (check fuses, check easily-accessible light wiring, etc.), then move on to the harder stuff if you haven't found your culprit. Have you changed anything recently?
Old October 17th, 2013, 01:18 PM
JBOD77
Jonathan
haven't changed anything recently. i guess i'll start with the fuses and then check the wiring. doesn't seem to be a lot of slack for the driver's side lamp, hope i don't have to drop the rear crossmember...am i correct in assuming that the high stop is tied to the drivers side taillight??
Old October 17th, 2013, 01:22 PM
RickM
Rick Mabus
95 D-90 ST
My lights go out all the time. Recently I went with LED bulbs that were $16. Double check the tabs inside the bulb sockets as rijosho said. Pullling the bulbs is a 2 minute job with a phillips head. I noticed that the vibrations of these trucks is actually pretty hard on the lead or whatever based connections on the cheap bulbs. I used some electric grease last time when installing the LED bulbs. The fact that yours go out completely when braking is odd. That said I like the idea of working from cheapest to most expensive. Check the tabs inside the sockets, check the bulbs and go from there.
Hope this helps.
Old October 18th, 2013, 11:34 AM
JBOD77
Jonathan
if i have a high stop bulb out, is it possible that that would bang up all the other lights??? no right?
Old October 18th, 2013, 11:40 AM
yes very possible. Not sure specifically about the 3rd brake light, but some things are wired in tandem.
Old October 18th, 2013, 12:18 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Third no. I removed mine along with the rusted out bar and my brake lights still work.
Jimmy Buffett
brake, ht
newbie help.. brake light?? rickauf Defender Technical Discussions 10 January 5th, 2008 12:00 PM
3rd Brake Light Flagg Defender Technical Discussions 16 March 11th, 2007 11:57 PM
3rd brake light Defender13 Wanted 3 March 24th, 2006 12:59 PM
3rd Brake Light Assembly Andrew Vick Wanted 2 February 4th, 2006 08:42 AM
Brake light on after brake install wicks Defender Technical Discussions 6 October 13th, 2003 07:01 PM
