Brake light issue - Defender Source
Old August 18th, 2017, 12:01 PM
Orb
none
Brake light issue
Can someone point me in the right direction for this electrical fix. 1992 110 200tdi.
My dashboard brake light is having some issues. When I first got it about 3 months ago there was no problem with the parking brake light. Pulled the handle up and light went on, lowered it and it went off. About two weeks ago I noticed that the light no longer went on when I pulled the handle up. Not a big deal I thought, either a burnt out bulb or maybe the activation switch on the handle went bad.
A week later and now I've got a really strange situation, the light is constantly on and disengaging the emergency brake has no effect. What does turn the light off (and this is just temporary) is repeatedly pressing the brake peddle. I'll tap the brake peddle a few times and the light will flicker, then dim, then go out. It'll stay out for about 30-40 seconds and then slowly come back on again. Have tried hunting down where the actuator switch is located but having no luck. Could I have crossed wires somewhere? or is it as simple as a misaligned or failing plunger switch. I would expect that the light would go on when I pressed on the brake peddle down not go off if things were wired right. I am probably not understanding some important electrical/mechanical connection between the emergency and regular brakes
Thanks for any help/advice
Orb
Old August 18th, 2017, 12:24 PM
Check the brake fluid level.
Old August 18th, 2017, 12:50 PM
Orb
none
Isn't it a straight mechanical connection between the emergency brake handle and the drum on the differential?
Regular brakes work fine, I think its just a wiring/switch issue but I guess it wouldn't hurt to check the fluid.
Orb
Old August 18th, 2017, 01:04 PM
I think you really need to figure out what the indicator is actually wired to display.
Who knows what is wired to that bulb on that truck. Could be factory, could be a bodge.
The reason you are confused is because you actually have no idea. You started with a deduction, and now that the logic behind your deduction is held in question, you are back to square one. "What does this bulb actually show me?" The problem is that we have no idea, either
Parking brake switch is located next to the diff lock linkage on the LT230. Brake fluid sensor is located on the brake fluid reservoir cap.
Old August 18th, 2017, 01:18 PM
Take a picture of which light is coming on. The brake warning light is connected to two or three things depending on the year and market.
brake, ht
newbie help.. brake light?? rickauf Defender Technical Discussions 10 January 5th, 2008 12:00 PM
3rd Brake Light Flagg Defender Technical Discussions 16 March 11th, 2007 11:57 PM
3rd brake light Defender13 Wanted 3 March 24th, 2006 12:59 PM
3rd Brake Light Assembly Andrew Vick Wanted 2 February 4th, 2006 08:42 AM
Brake light on after brake install wicks Defender Technical Discussions 6 October 13th, 2003 07:01 PM
