Brake issues - Defender Source
Old July 27th, 2016, 04:57 PM
wanabewheelin's Avatar
wanabewheelin
Michael Sword
1989 110 200TDI, RHD
Brake issues
Sure this easy . . . but heading out in the morning . . . realized brake lights are not working properly. Just got a new brake switch in and installed. Brake lights work when the lights are off, but when I turn them on don't see the change in light.
Signals work...
Perplexed. Recently switched to LED's and IIRC they tested correctly.
Gotta run out, but appreciate any thoughts on the issue.
Old July 27th, 2016, 05:22 PM
Naplm00
Matthew
did you get the running light and the brake light connections switched at the lamp side? when you depress the brakes and the lights are off you are probably lighting up the running light circuit...not the brake light circuit.
With the running lights on you already have the brighter "brake light" circuit activated and depressing the pedal and activating the running light circuit isnt going to make them any brighter....make sense?
TLDR switch the hot wires on the lamp side.
Also I texted you, you still coming for that part?
Old July 27th, 2016, 05:28 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
See Mike this is what happens when you get a smoking deal on something like, oh I don't know...a new engine. It F's up yin and the yang and then stupid shit starts acting up.
brake
Strange brake controller issues sro Defender Technical Discussions 4 January 14th, 2014 01:16 AM
Brake and clutch issues beast Defender Technical Discussions 5 January 13th, 2014 12:42 PM
Lashcap issues/valve cap issues trybul Defender Technical Discussions 6 January 9th, 2012 12:46 PM
Brake Issues, Master Cylinder? NashvilleRedD90 Defender Technical Discussions 3 July 11th, 2008 12:46 PM
Emergency Brake Issues Ragland Defender Technical Discussions 10 April 7th, 2005 07:09 PM
