Brake issue (disco) - Defender Source
Old April 11th, 2010, 07:50 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Brake issue (disco)
Found a few minutes this afternoon (around drilling holes in the studs in our addition to run wires) to work on diagnosing the soft brakes on the disco. It's a 95, no fuse in the ABS system. Pads measure reasonable thickness as do the rotors. The seals at the brake fluid resevoir were leaking, so I replaced them, have bled the brakes twice and the Booster tests OK (by seeing that it drops slightly when the car is turned on). My next thought is to replace pads thinking that they might be glazed/contaminated. Any other thoughts on next steps? Oh, fluid level stays the same, so I think MC is ok.
Tony
brake, disco
Weird brake light issue on my 97 Please HELP! Cyborg Defender Technical Discussions 8 July 12th, 2009 01:04 PM
3rd Brake Light Issue fleabus Defender Technical Discussions 2 February 7th, 2007 07:49 PM
Help empty my garage! Ton's of parts.. RedRhinoProducts For Sale - Parts 12 June 1st, 2005 09:24 AM
