Brake/Friction Pad (and maybe Brake Disc/Rotor) Replacement - Page 4 - Defender Source
Old March 16th, 2011, 12:17 PM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
Originally Posted by DNinety View Post
Huh, that's weird...if I compared my brake job to a girl, the calipers were the panties. No problems getting them off whatsoever, once you get that far. I guess the prior owner must have had them off recently.....
My calipers were so bad that the place that rebuilt them asked if my truck had been at the bottom of the Chicago River for an extended period of time. I have a picture of the calipers before and after here:
http://found90.wordpress.com/2010/07/03/fourth_of_july/
Maybe my truck isn't quite as easy as yours.....
Old March 16th, 2011, 01:06 PM
TS888's Avatar
TS888
Tony Sims
1984 110
This is a bad caliper...
Tony
1984 110 "Smokey" (sold)
Old March 16th, 2011, 03:55 PM
DNinety's Avatar
DNinety
JP
1984 Ninety 200TDI
So I guess when things are "lost" they tend to turn to shit. Then when they are "found" you have a tougher time of it. But it looks like you've conquered it. Well done on the rehab/rebuild, she looks great. Now its time to wheel! Paging Clarence....
ac, brake
