Brake Fluid Light - Defender Source
Old January 6th, 2015, 09:46 PM
brettm's Avatar
brettm
Brett
97 D90-SW, Arles +4.6
Brake Fluid Light
My brake fluid light isn't coming on when the reservoir is low. The bulb is OK - as it lights during ignition cycle. Even if I disconnect the wires from the reservoir sensor - the bulb doesn't come on.
Any clues on where to look?
Old January 6th, 2015, 09:55 PM
I believe all the sender does is ground the bulb when it drops. Check the ground. Earth is the usual suspect for these kinds of issues.
Mark Kellgren
KM4BOR
Old January 6th, 2015, 10:09 PM
I have the opposite problem. I swapped the cap and everything so I am interested in any solution
brake, ht
Brake fluid leaking into servo? easy Defender Technical Discussions 3 August 3rd, 2009 04:55 PM
Amount of brake fluid required for renewal JFD Defender Technical Discussions 6 September 23rd, 2008 06:24 PM
Brake fluid Defender13 Defender Technical Discussions 2 August 27th, 2007 09:33 PM
Replacing brake fluid Antonios Defender Technical Discussions 2 September 27th, 2006 09:09 PM
