Brake fluid leaking into servo? - Defender Source
Old August 1st, 2009, 04:51 PM
easy's Avatar
easy
Dan Duncan
White '94 Disco 1
We just replaced the Clutch Master cylinder on our 95 D90 and in doing so, removed the Brake Master Cylinder from the front of the servo to give us some more room. When we put the brake MC back on, we didnt quite get it on right (The little rod wasnt lined up in the plunger) so we took it back off and then put it back on correctly BUT now after just a few pumps of the brake, the reservoir empties. After some looking I noticed fluid inside of the servo. Could this be a bad vacuum seal around the plunger?
Old August 2nd, 2009, 01:55 AM
Time for a new master cylinder. You messed up the seals when you put the rod in wrong. If you want to be cheap, you can take it apart and try to get the seals correctly seated, but I would just buy a new one. (or you forgot to put a brake line back on).
Old August 2nd, 2009, 11:41 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
I did the same thing, ended up changing the servo..the rod in the servo just ended breaking off,..even though I was carefull..I looked inside the servo and found brake fluid inside.
I purchased another master & servo.
not sure if the master was still good or not, I just did not want to chance it..when it comes to brakes.
Old August 3rd, 2009, 04:55 PM
easy's Avatar
easy
Dan Duncan
White '94 Disco 1
I didnt remove any of the lines so that wouldnt be it, do you think I would need to replace the MC? Do they go bad very often? Or would I just need to rebuild? I probably just need to tear it apart and look for myself. I think my servo should be fine, unless having all that brake fluid inside would screw something up???
brake
Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest Buckon37s Defender Technical Discussions 223 September 1st, 2014 01:49 AM
Replacing brake fluid Antonios Defender Technical Discussions 2 September 27th, 2006 09:09 PM
Bad Servo? dfscott Defender Technical Discussions 0 March 25th, 2006 02:09 PM
Brake Servo dimcon Defender Technical Discussions 0 May 26th, 2005 09:20 PM
