Brake fluid leak? - Defender Source
Old March 21st, 2013, 02:04 PM
Surf90's Avatar
Surf90
C.S.
1989 Defender 110 200tdi
Brake fluid leak?
Any thoughts on what's going on here? Looks like a leak coming from between the brake reservoir and the master cylinder??
Old March 21st, 2013, 02:08 PM
Probably. There is a seal there and they do die. You can get a new reservoir with seal.
Old March 21st, 2013, 03:56 PM
61rover's Avatar
61rover
John Crouse
x2. If the master is good, just replace the reservoir. Might even get way with just an o-ring.
Old March 21st, 2013, 04:18 PM
NO!!!!!!! It is nearly 20 years old (there is a date stamp cast into the top), your life depends on it, and some of the rubber seals have failed already and a new one is about $100. Replace the whole master cylinder with a genuine or lucas girling brand replacement. Use castrol GTLMA brake fluid.
Takes a couple hours to swap the MC and bleed.
Old March 21st, 2013, 04:34 PM
Surf90's Avatar
Surf90
C.S.
Thanks guys! I'll check that date stamp, but my guess is its original and ill just do the whole master.
brake
Brake Fluid Resevoir leak Lriwater Defender Technical Discussions 13 December 3rd, 2010 08:37 PM
Replacing brake fluid Antonios Defender Technical Discussions 2 September 27th, 2006 09:09 PM
Rear brake caliper leak cgalpin Defender Technical Discussions 11 July 8th, 2005 11:56 AM
New Leak d901560 Defender Technical Discussions 0 May 2nd, 2005 03:21 PM
