Brake fluid dot 4 vs Castrol 5 - Defender Source
Old March 25th, 2012, 07:13 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
After doing my clutch and using the Castrol, the clutch was a bit squirely. I bleed it again and it still was the same. Had some shutter in the clutch, especially when cold. When I used the motive bleeder to bleed it the clutch fluid was a bit grey. It was also grey when I flushed it to replace with the dot 4. With the dot 4 the shutter has gone away and the clutch seems more consistent.
The master,the slave and the soft hose were new when this all started.
Thought this was interesting, thoughts?
Old March 25th, 2012, 08:00 PM
I literally just did mine as well last week, using Castrol GT LMA and the Motive Black Label bleeder. Mine was grey as well when I flushed it. After the first flush drove it about 60 miles and noticed the reservoir fluid was grey-ish again so re-flushed it - been good ever since. Didn't act squirrelly like you mentioned at all before or after, but did seem to perform nicely since the flush (of course it's probably my imagination or wishful thinking that it's "better" now ).
Perhaps some air in the system? If you're trying to cheat and underfil the Motive it will suck air down the line without you realizing it (found this out on my second flush when I was trying to be cheap and not open another bottle).
Old June 17th, 2013, 08:36 PM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
Folks I ordered Castrol GT LMA brake fluids through Amazon. The package arrived this evening. When I opened the box they sent me Castrol Brake Fluid DOT 4. Is this the same as Castrol GT LMA?
Old June 17th, 2013, 09:29 PM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
I understand it supercedes GT LMA. I get my brake fluid at carquest and they told me the part number for Castrol DOT 4 supercedes LMA
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old June 17th, 2013, 09:42 PM
Tom, was the castrol in a sealed bottle? It takes on water once opened.
LMA is NLA. Not sure what I am going to use when I run out.
Old June 17th, 2013, 10:25 PM
Holy cow...when did that happen???
Old June 17th, 2013, 10:33 PM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
Correct. Castrol DOT 4 supercedes GT LMA.
Old June 17th, 2013, 10:34 PM
Normal Castrol DOT 4 works fine.
Old June 18th, 2013, 07:02 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
http://www.castrol.com/castrol/secti...tentId=7081185
The Castrol is still LMA, it's just not in the name anymore.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old June 18th, 2013, 07:58 AM
Maybe I am dumb but I havent used LMA in 7 years.
brake
Dot 4 fluid trybul Defender Technical Discussions 2 September 2nd, 2011 08:29 AM
Brake Fluid Resevoir leak Lriwater Defender Technical Discussions 13 December 3rd, 2010 08:37 PM
Brake fluid Defender13 Defender Technical Discussions 2 August 27th, 2007 09:33 PM
Replacing brake fluid Antonios Defender Technical Discussions 2 September 27th, 2006 09:09 PM
