Brake flares - Defender Source
Old June 15th, 2012, 02:16 PM
Brake flares
It appears that the brake flares are DIN, is that so? Can one use just regular old bubble flare tool or must one buy/rent one of the fancy turret style flare tools that make official DIN flares?
Old June 15th, 2012, 02:30 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
on the truggy I just used the lines that have premade at advance auto and I dont think those flares are anything special
Old June 15th, 2012, 02:54 PM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
I used the premade ones and bent them to fit, and they worked okay. Until a couple of weeks ago, when one of them burst at a rusty spot. I bought some of the Cunifer brake line material, a few handfuls of fittings, and the fancy flaring tool. After flipping around in the driveway for a while, I think I an free of the curse of steel brake lines.
Go here: http://www.fedhillusa.com/
John Karlsson
Hope Valley, RI
Old June 15th, 2012, 02:59 PM
John, does the Fedhill tool make DIN flares?
Old June 15th, 2012, 03:11 PM
John_Karlsson
John Karlsson
The 007C tool makes SAE and DIN. You can buy the basic tool and add whatever dies you want.
John Karlsson
Hope Valley, RI
Old June 15th, 2012, 07:45 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Fromthe Fedhill site
The SAE/double (inverted/45degree) flare and the DIN/ISO bubble flare. We will refer to them as SAE or DIN flare.
This is what I use: http://www.otctools.com/products/bub...aring_tool_kit
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old June 15th, 2012, 07:52 PM
Alright so if you make a bubble flare and use a regl'r old 10 mm nut on your connection, will it seal correctly?
Old June 15th, 2012, 08:16 PM
John_Karlsson
John Karlsson
I don't know about the "bubble," but I did learn that the SAE 45 degree flare is used for the DIN female fittings.
John Karlsson
Hope Valley, RI
Old June 16th, 2012, 06:08 AM
Antichrist's Avatar
Antichrist
Tom Rowe
I haven't had any issues with DIN/ISO bubbles made with that OCT flaring tool when connected to my calipers and flex lines. You do have to use nuts designed for DIN/ISO bubble flares.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
brake
Series I II IIa III Heystee disc brake conversion kit kullberg Series Technical Discussions 8 June 14th, 2012 03:42 PM
Parking Brake and Rear brake light gas-man Defender Technical Discussions 9 February 20th, 2012 11:40 AM
Emergency Brake Issues Ragland Defender Technical Discussions 10 April 7th, 2005 07:09 PM
