Brake Fade - Defender Source
Old June 27th, 2016, 07:46 PM
sandman913's Avatar
sandman913
1985 110 200 Tdi
Brake Fade
My brake pedal will go to the floor and I will lose stopping power if I keep the pedal depressed. It will stop if I do short bursts by feels like the system is losing pressure. Is there a way to diagnose the booster?
Old June 27th, 2016, 07:54 PM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
If the booster fails, the pedal effort will go up dramatically, but the pedal should not go to the floor. My guess is the master or slave cylinder or low fluid. Is it leaking fluid anywhere (under the hood or from the bell housing)?
Angus
Old June 27th, 2016, 08:20 PM
DocB
David
1989 D110
Have you bled the brakes lately?
Old June 27th, 2016, 08:27 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
The simple things to check..
1. Check each caliper to see if its wet around the bleed nipple. You can do this without taking any wheels off. Maybe you're lucky and you just a bleed valve loosen up on you.
2. Follow the brake lines out of the caliper to where they become metal and check if any of the joints are wet. If you have SS lines than inspect the entire line for wear. If you have rubber lines, check to see nothing rubbed a hole in the line.
3. If everything is dry around the wheels, crawl undernearth and look above the rear differential at where the lines go forward. Check for spots of extreme rust that could have caused a pinhole leak. Lastly check the lines as they route through the engine bay
4. If everything is dry, replace the master cylinder. It's not the booster.
5. Oh, and if you are extremely extremely bad at general maintenance and let your pads get to the point where you're wearing down the backing plate, it's possible the piston on a caliper is so far pushed out that you over extended the seal. So if you have some pads that are absolutely down to nothing, than I would suspect that caliper.
Old June 27th, 2016, 09:13 PM
You have a leak, not a booster failure. The master cylinder can leak into the booster which won't leave any leaks on the ground.
Old June 27th, 2016, 09:32 PM
x2 - I had the same symptoms op described - it was the master cylinder
Old June 27th, 2016, 09:53 PM
Naplm00
Matthew
Make sure to bench bleed that master if you replace it.
Old June 28th, 2016, 09:37 AM
sandman913's Avatar
sandman913
1985 110 200 Tdi
Thanks guys. will look into the MC and leaks.
brake
Brake fade when off roading Davis Defender Technical Discussions 20 May 30th, 2014 11:51 AM
Brake/Friction Pad (and maybe Brake Disc/Rotor) Replacement rijosho Defender Technical Discussions 62 March 16th, 2011 03:55 PM
Left brake lights work....the right and door brake lights won't? beko35 Defender Technical Discussions 4 June 27th, 2009 02:12 PM
'95 Factory Radio Fade/Treble/Bass Button Not Working gamberik Defender Technical Discussions 1 March 30th, 2005 01:05 PM
Brake light on after brake install wicks Defender Technical Discussions 6 October 13th, 2003 07:01 PM
