Brake Disc Replacement Help - Defender Source
Old September 26th, 2014, 06:10 PM
CMorrow89's Avatar
CMorrow89
Chuck Morrow
97/Defender 90 # 378
So I finally got around to replacing my shocks and while I was at it decided to replace brakes. Im stuck trying to seperate the disc from the drum (Front, '97 NAS). Retaining bolts are out. Is the hub now supposed to just seperate from the disc (as in man up) or is there another piece of the hub on the inside side of the disc that is supposed to come off first to allow the 2 to seperate. The shop manual doesnt describe it that way.
Old September 26th, 2014, 06:35 PM
I'm not really sure where you are at. You first remove the hub along with the disc from the axle. There are then bolts on the back side that bolt the disc to the hub. Stupid design, but such as it is.
Old September 26th, 2014, 06:37 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Check for a small phillips countersunk screw that is used to line up disc with hub.
Once it's off, wack it off toward the outside with a rubber mallet, or a regular hammer but using a good block of wood to protect disc.
Leave 3 wheel nuts on to prevent disc to fly out and land on your toe.
- Charles Eames
Here is a writeup: http://www.paddockspares.com/blog/re...-discs-part-1/
Old September 26th, 2014, 06:38 PM
Huh??? Not on a Defender....
Old September 26th, 2014, 06:40 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Check for a small phillips countersunk screw that is used to line up disc with hub. Once it's off, wack it off toward the outside with a rubber mallet, or a regular hammer but using a good block of wood to protect disc. Leave 3 wheel nuts on to prevent disc to fly out and land on your toe.
Sorry, just realized I'm giving you the procedure for a discovery.
------ Follow up post added September 26th, 2014 06:41 PM ------
My bad.
- Charles Eames
Old September 26th, 2014, 06:43 PM
Not on a Discovery 1 either. "Traditional" coil sprung Rovers. RRC, Disco 1, Defender have the disc bolted to the back side of the hub. That is one reason the Disco 1 changed to the smaller hub bolt spacing, to allow for a normal style brake disc.
Old September 26th, 2014, 06:51 PM
CMorrow89's Avatar
CMorrow89
Chuck Morrow
Attempting to attach photo of disc and drum off truck. Bolts out. I dont see the screw but it seems that there is a piece in the center of the inside side of the disc that is part of the drum that needs to come off to allow the 2 to seperate. Hopefully the pic shows this (first time posting a pic)
Old September 26th, 2014, 07:04 PM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
You need to tap the hub away from the disc on the flange that contains the rubber seal. Use a block of wood or something to prevent damage to the flange which would occur with just a hammer. I just did this a week or so ago. Here's a pic of my work and a screenshot of what the workshop manual says.
Name:	Screen Shot 2014-09-26 at 5.54.15 PM.png
ID:	103727   Click image for larger version
Old September 26th, 2014, 07:17 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
You are correct, I was saying for a D2, did it many times lately swapping and testing ABS sensors.
- Charles Eames
Old September 26th, 2014, 07:20 PM
CMorrow89's Avatar
CMorrow89
Chuck Morrow
Thanks for the help. Just needed the assurance that I hadnt left something out. Got a little more muscle (i.e. 12 oz's) and seperated the two. Just frozen together.
Again, appreciate the advice.
Old September 26th, 2014, 07:39 PM
ezzzzzzz
Mark Garrenton
I had one so tight it actually cracked the hub attempting to separate it.
Old September 27th, 2014, 10:36 AM
Get a bigger hammer, pb blaster might help
ac, brake
Brake/Friction Pad (and maybe Brake Disc/Rotor) Replacement rijosho Defender Technical Discussions 62 March 16th, 2011 03:55 PM
Rear disc brake options kellymoe Defender Technical Discussions 44 April 9th, 2008 09:34 AM
Warning on Raybestos disc Brake pads for D90 Antichrist Defender Technical Discussions 0 September 6th, 2007 07:34 AM
Rear disc brake 110 Retrofit Defender Technical Discussions 23 May 15th, 2006 03:32 PM
3" BS and Disc Brake Protection Jay Defender Technical Discussions 0 November 27th, 2005 10:18 AM
