brake disc replacement - Defender Source
Old April 11th, 2015, 10:09 PM
CaptMidnite
Daniel Choi
94 NAS Defender 90 ST
In the process of replacing the front brake discs (NAS D90 1994). Couple questions:
1) Worth it to upgrade to the cross-drilled vented rotors (about $129 for ProLine brand) vs $80 for regular Proline?
2) Loctite or not on the bolts holding the rotors to the hub? Won't using Loctite throw off the torque spec readings? (40 ft lbs, I think)
3) Same questions regarding brake caliper bolts.
4) Maybe a stupid question, but the pads still have plenty of life on them. Replace anyway? ($134 for genuine replacement pads)
Old April 11th, 2015, 10:25 PM
1) No. Dumb waste of money on any car.
2) Yes, as per the manual, which you should read.... I'm pretty sure it is more than 40 ft-lbs. Locktite does not affect torque settings.
3) No. Again, read the manual...
4) If the rotor is bad, then you need to replace the pads.
Make sure you change the hub seal and use an OEM RTC3511. New hub lock washer. Make sure all caliper pistons are free.
ac, brake
Brake Disc Replacement Help CMorrow89 Defender Technical Discussions 12 September 27th, 2014 10:36 AM
Brake/Friction Pad (and maybe Brake Disc/Rotor) Replacement rijosho Defender Technical Discussions 62 March 16th, 2011 03:55 PM
Rear disc brake options kellymoe Defender Technical Discussions 44 April 9th, 2008 09:34 AM
Rear disc brake 110 Retrofit Defender Technical Discussions 23 May 15th, 2006 03:32 PM
3" BS and Disc Brake Protection Jay Defender Technical Discussions 0 November 27th, 2005 10:18 AM
