Brake Conversion Question - Defender Source
Old April 2nd, 2011, 08:54 PM
punter
1966 Series IIA
I am converting the rear drum brakes on my D110 to disk brakes. I've already fitted the brackets, calipers, hubs and rotors. Now, I'm getting ready to start plumbing the system. I'm going to run all new 3/16" tubing with new fittings.
What I'm wondering about is if I will need to change out any of the other components. I don't imagine that there would be any issues with the Brake Servo or Master Cylinder... but what about a proportioning valve?
I have to imagine that there is something that I need to be doing to ensure that the front brakes are getting more braking power than the rear, in order to avoid rear-wheel lock-up.
Any thoughts?
Old April 3rd, 2011, 06:18 AM
TS888's Avatar
TS888
Tony Sims
1984 110
This is a fairly common conversion here in the UK, and no one seems to have any brake balance problems. You can always add a restrictor to the rear line if you find the balance is off.
Tony
1984 110 "Smokey" (sold)
Old April 3rd, 2011, 07:26 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
I've done several, on 90 and 110's (changing the rears to disc, from drums) and never had any problems with handling, MoT tests or anything.
just fit & forget, no need to chnge any of the other plumbing/PDWA valves etc.
Old April 3rd, 2011, 07:25 PM
punter
1966 Series IIA
Great, Thanks Guys!
brake, conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Hydroboost Brake Conversion. ajh Defender Technical Discussions 20 March 7th, 2011 05:19 PM
RHD to LHD conversion question Gkase Defender Technical Discussions 14 September 14th, 2008 08:01 AM
Range Rover Front Brake Caliper Question TDI Guy Misc. Chit-Chat 10 May 24th, 2006 08:14 PM
Brake Light Question waveridin1959 Defender Technical Discussions 6 May 4th, 2005 02:42 AM
