brake calipers - Defender Source
Old December 4th, 2008, 11:39 AM
phunter
phunter
1993 NAS 110
brake calipers
best place to get brake parts and shocks for 93 110. bilsteins or another more stock shock? want to keep it original
Old December 4th, 2008, 11:52 AM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
IMO, shocks and original condition are not related. If you wanted to be anal then Woodhead shocks would be original equipment but I would not wish them on anybody. I would go with OME or Bilsteins.
Brake calipers and pads, the usual suspects...Rovers North, Atlantic British, TLR, RDS, British Pacificm whoever you like, just don't get them from Napa or Autozone.
Old December 4th, 2008, 02:03 PM
If you need calipers, I suggest upgrading to vented rotors and associated D90 calipers and pads.
Old December 4th, 2008, 02:11 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Do the pads and rotors just bolt right on? What else do you have to change?
Old December 4th, 2008, 02:27 PM
landrovered
S. Smith
I suggest you invest in a manual, it is a great help.
The disk (rotor) is bolted to the hub, the vented rotors will replace your solid ones. The caliper is bolted to axle by two bolts that require threadlocker blue when you put them back on. The pads for the vented discs are held into the caliper by two clips that are held in by two rods that are secured by cotter pins. The difference between the calipers you have now and the vented ones is a spacer that fits between the calipers to allow them to fit over the wider vented disks.
It is a DIY job but if you are in doubt of your ability, get a mechanic to do it so that you will have properly functioning brakes and the bearings in the wheel hub will be greased and adjusted properly.
Old December 4th, 2008, 02:30 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Right, I am not concerned about the work, but don't want to start the job and find out I need something else. I guess my question is more...do the brake lines still fit or do they need to be changed, and what about the caliper mounting bracket? Do I have to get the D90 one or can I reuse the D110 bracket?
Thank you for your help.
Old December 4th, 2008, 02:42 PM
landrovered
S. Smith
The D90 rotors and calipers will bolt right up, ditto the brake line. Sorry I did not know what your level of mechanical aptitude was.
The spacer is in the caliper itself to make them wider if that was confusing.
Old December 4th, 2008, 02:55 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Ok, that makes sense then. Thank you!
brake
Rear brake calipers staying engaged. FlaD90 Defender Technical Discussions 4 April 12th, 2009 07:29 PM
FS D110 front brake calipers ECR For Sale - Parts 1 April 13th, 2008 08:10 PM
For Sale - Brake Calipers And Pistons HUMMER80401 For Sale - Parts 6 May 20th, 2006 11:46 AM
Clogged brake lines? Heath Defender Technical Discussions 11 February 24th, 2006 08:39 AM
Front Brake Calipers 1of40 Defender Technical Discussions 7 December 30th, 2003 12:46 PM
