brake caliper piston - Defender Source
Old July 15th, 2009, 09:22 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
Is it much of a job to take these out, i have one sticking. Also is it better to buy nrw ones or clean the old. Been in plenty of water and mud over the years and never cleaned
3rd low and BOOT IT
Old July 15th, 2009, 10:00 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
You can use compressed air to pop them out. You have the caliper off anyway so just replace it. Thats what I did last time that happened to me. After you pay for a rebuild kit and fiddle with it it's just easier to pop a new caliper on.
Old July 15th, 2009, 10:01 AM
Rubber tipped airgun pops them right out. YOu have to make sure to hold the other side in place though with something.
Old July 15th, 2009, 12:16 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
There is a guy in the UK selling s/s brake pistons.
I can search for his web/phone/mail if you're interested.
- Charles Eames
Old July 15th, 2009, 11:56 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Easy to get out, in a pinch you can just use pliers.
Personally, I'd suggest replacing instead of cleaning. When I rebuilt mine, the plating was flaking off of the pistons causing it to rip the seals. And the areas that the plating had already come off was rusting enough to further cause leaks and sticking.
-Hans
My oil line fix
My 100k stopped odometer fix
brake
Brake caliper reseal kits KevinNY Defender Technical Discussions 1 January 23rd, 2009 05:50 PM
Front left Brake caliper tomaco1 Defender Technical Discussions 5 October 17th, 2008 07:36 AM
Range Rover Front Brake Caliper Question TDI Guy Misc. Chit-Chat 10 May 24th, 2006 08:14 PM
Rear brake caliper leak cgalpin Defender Technical Discussions 11 July 8th, 2005 11:56 AM
