You didn't mention if it is a cracked fitting or line but here are a few options:
You may be able to buy 3/16" compression fittings at a lowes or home depot and piece the line together to give you decent brakes.
You might be able to buy a short brake line from an auto supply to replace the line or cut it to use with the compression fittings.
Another option would be to silver solder over the crack temporarily just to get home.
And finally if you remove the line and find a reman caliper at an auto supply with a similar line that will work, you can remove the line from the reman unit and install it in your unit.
A less desirable temp fix would be to possibly remove the bleeders and use them to plug the lines going to the other half of both front calipers.
This would give you weaker brakes that would be better than none at all, but you would have to be ultra careful on the road.
Just back from underneath it and noticed rub marks on the inside of the rim. Looks like the top caliper bolt went missing and allowed the bend in the hard line to become a pivot point of movement and therefore formed a crack in the bend of the line.
Any auto parts store should have an 18" length of 3/16" hardline with metris bubble flare fittings. You shouls be able to bend it by hand to work. O compressions needed.
ACE will be your best bet finding a fine thread metric bolt for the caliper.
It's too bendy to repair in place. Any auto repair shop can fix it. They can reuse the nuts from the bad pipe. They can just copy the bends from it. The caliper bolt is metric 10 fine thread. Shouldn't be too hard to find.
You're done for the day but repair is simple.
Sorted or missing caliper bolt with a replacement. Advance Auto had the compression coupling and the length of metal brake line to make the patch. Quick 1 man brake bleed to get the pedal hard. Might get me home! Thanks for the guidance everyone.
Related Threads
Defender Source Forum
1M posts
24K members
Since 2003
