brake caliper bolt problem - Defender Source
Old April 22nd, 2008, 10:43 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
93 110, 90 RockRR buggy
I started to swap the front calipers on my 110 to the 90 front version so I can run vented rotors. To my pleasant surprise the top 12 point bolt head is stripped. Short of removing the entire outer from the axle tube and dealing with it, does anyone have a suggestion?
Old April 22nd, 2008, 11:05 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
http://www.northerntool.com/webapp/w...3374_200263374
try one of these or weld a bolt to it
Old April 22nd, 2008, 11:15 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
thanks, I'll take a look again but my first impression was that it would be hard to weld a bolt to it in that recessed area.
Old April 23rd, 2008, 09:26 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
it ain't going to be easy
ok jb weld a socket to it
Old April 23rd, 2008, 09:30 AM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
you got that right!
Old April 23rd, 2008, 09:31 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
jb weld works just kinda fubars the socket
Old April 23rd, 2008, 12:16 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
In very tight locations banging a smaller socket on to the bolt has worked for me. Only problem is that those caliper bolts can require a lot of torq to get off.
you may need to weld something to it. good luck
Old April 23rd, 2008, 12:40 PM
That sux. Welcome to the world of 110 ownership. I had a brake line break when I was replacing the cluch master. Yes, those are scarcely related systems, but it turns out that my DS front brake line was paper-thin by the shock tower and the slightest disturbance of the master broke it. Please inspect your truck carefully. Also, I think that hammering a 12mm onto it and impacting the socket off will do the job. Naturally, this should be a harbor frieght socket and not a Hazet one.
Old April 23rd, 2008, 01:19 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
Yeah, I'm with you and the crap factor of the brakes. I'm actually surprised this thing stops at all based on the rust on the disc where the pad is obviously not contacting the disc.
It can't hurt to try the 12mm socket although the bottom bolt required the use of a 3ft breaker bar to loosen. I did PB Blaster the top one so we'll see.
Old April 23rd, 2008, 01:52 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
x2 I have a set of these and they work wonders. I'd try them before welding. Welding can weaken the bold and it could snap off so it has to be drilled out. On the + side, the heat might loosen it enough it will come out without breaking.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old April 23rd, 2008, 03:43 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Just hold your mouth right-------------
Or tuck back that tumor so you can see what you are doing-----Bad taste------I know
legend in my own mind
Old April 23rd, 2008, 05:24 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
It's not a toooma!
Old April 23rd, 2008, 07:20 PM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
Been there before...
I welded an oversized nut on the bolt head, the bigger the treaded hole in the nut the better the plug weld to the stripped bolt. I think the heat also helps lossen it up.
Good Luck
MH
--Benjamin Franklin
Old April 24th, 2008, 11:25 AM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
Pendy: That was lower than Whail Shit. Even for you.
Thanks for helping me shore up the list of friends I will have in Hell
--Benjamin Franklin
Old April 24th, 2008, 02:15 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Heat, apply lots of heat- LR used stud lock on lots of those bolts in the factory and they shear off rather than come out... ended up buying a new swivel housing as it was easier than drilling out everthing that had sheared when I was re-shimming the bearings in the swivel
Mike Hammond
Old April 24th, 2008, 02:24 PM
Heat plus bolt-out thing will work. Or the ever popular air chisel as a wrench method . . . .
Old April 26th, 2008, 12:30 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
With great skepticism, I went and purchased this kit...Bowtracer you are the man!!! Miraculously this rounded, rust siezed bolt came right out on the first try. You made my weekend man, thanks!
Old April 26th, 2008, 01:38 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Well in Chitown we have our share of rusted SHIT! Glad it worked! I am sure you will like the upgrade as well!
Old April 28th, 2008, 01:29 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
BTDT. Those extractors work great.
Part of the problem I've had in the past is with the placement of those bolts, with the head facing away from me, is remembering to turn the bolt in the right direction. I've mangled the head up in the past, and then realizing that I was turning it in the wrong direction.
Old April 28th, 2008, 01:47 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
newest problem of this conversion. The 12 point 13mm bolt that came out of the stock 110 caliper mount is coarse thread. All the bolts I have from the 94 D90 caliper mount are 12 point 13mm but fine thread. Both bolts appear to be identical except for coarse vs fine thread.
brake
Parking brake problem, handle popping back UP. Hans Defender Technical Discussions 14 January 19th, 2010 02:34 PM
13mm Front Brake Calip. Unit Bolt chrisvonc Wanted 2 July 31st, 2008 08:50 AM
Rear brake caliper leak cgalpin Defender Technical Discussions 11 July 8th, 2005 11:56 AM
Door top bolt problem Buckon37s Defender Technical Discussions 10 June 3rd, 2004 03:04 PM
