brake caliper bolt problem - Page 2 - Defender Source
Old April 28th, 2008, 07:07 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
That doesn't sound good! I have never seen a couse threded bolt there..
Were the rest of the bolts the same??
Old April 28th, 2008, 07:50 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
To be honest, as it's still 12pt heads I wouldn't be too concerned just yet. It's not like somebody just grabbed whatever was laying around and pulled a handfull of 12pt bolts. Do the threads in either one look like they forced a course threaded bolt into a fine thread hole?
-Hans
My oil line fix
My 100k stopped odometer fix
Old April 28th, 2008, 09:05 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
93 110, 90 RockRR buggy
-Hans
Nope, threads in the bracket look good, both bolts are coarse thread (I've only taken the driver's side caliper off so I'm assuming I'll find the same thing on the passenger side.) The bolt looks exactly like the 12 pt fine thread; same length 40mm, diameter and require a 13mm socket. I'd assume if someone dorked up the threads they would have used a more common bolt.
Old April 28th, 2008, 11:55 PM
pendy's Avatar
pendy
jim pendleton
89'd90
I did not dig any up today. I can take some off a truck if you can not get some soon enough, but don't have any spares.
JP
legend in my own mind
Old April 29th, 2008, 11:10 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
I Probably have some coarse thread caliper bolts.. I'll dig around and see.
Keith
Big, Red and ... aaa Red..
brake
Parking brake problem, handle popping back UP. Hans Defender Technical Discussions 14 January 19th, 2010 02:34 PM
13mm Front Brake Calip. Unit Bolt chrisvonc Wanted 2 July 31st, 2008 08:50 AM
Rear brake caliper leak cgalpin Defender Technical Discussions 11 July 8th, 2005 11:56 AM
Door top bolt problem Buckon37s Defender Technical Discussions 10 June 3rd, 2004 03:04 PM
