brake caliper - Defender Source
Old January 21st, 2015, 09:34 AM
Mes788
Mike S
110
brake caliper
I have a quick technical question that maybe someone can answer. I have a 86 D110.
I have a LF brake caliper seizing up and I was going to replace it. Can I replace it with a caliper from a 93 NAS 110?
I am looking to get something quick and see that my local parts store can get this in overnight. I was going to order the rebuild s/s piston kit if I was going to do myself but I have a local part time mechanic looking at it and figure it would take longer to rebuild and would rather order a refurb set.
Any suggestions?
Thanks in advance...
MIKE
Mike S.
Naples, FL.
Old January 28th, 2015, 02:03 PM
michael67's Avatar
michael67
Michael White
110 Tdi
From what George @ RDS told me, you can use DiscoveryII calipers; you'll need to buy new rotors and brakepads, of couse. I did this and it still stops just fine, even pulling a trailer, no warped calipers or fading. I did have to make new steel lines that run from the rubber hose to the calliper itself.
brake
Front left Brake caliper tomaco1 Defender Technical Discussions 5 October 17th, 2008 07:36 AM
brake caliper bolt problem WhiteD90 Defender Technical Discussions 24 April 29th, 2008 11:10 AM
Brake Pads for Lockheed caliper - D-90 JackW Defender Technical Discussions 1 May 30th, 2006 12:20 AM
Range Rover Front Brake Caliper Question TDI Guy Misc. Chit-Chat 10 May 24th, 2006 08:14 PM
Rear brake caliper leak cgalpin Defender Technical Discussions 11 July 8th, 2005 11:56 AM
