Brake booster question... - Defender Source
Old July 11th, 2010, 11:03 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
When holding the brakes when slowing down to a stop I loose the the assisted braking right at the end. Would this be related to the booster itself or a bad vacuum pump ?
Checked the lines with no apparent leaks.
Thanks !
Pat
Kirk Lazarus, Tropic Thunder
Old July 12th, 2010, 02:33 AM
On a V8 there is a check valve. That would be my guess.
boost, brake
brake booster? tomaco1 Defender Technical Discussions 3 October 2nd, 2009 04:15 PM
Quickest way to change a brake booster? Hoosier Defender Technical Discussions 1 May 13th, 2009 08:29 PM
cracked brake booster: interchange? jaherring Defender Technical Discussions 4 November 29th, 2007 08:33 PM
Range Rover Front Brake Caliper Question TDI Guy Misc. Chit-Chat 10 May 24th, 2006 08:14 PM
Brake Light Question waveridin1959 Defender Technical Discussions 6 May 4th, 2005 02:42 AM
